Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 38 of 38
Thread: Beta Testing
  1. #31
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Damn, that's sound pretty ugly. It was a good pickup on your end to equate their use of pirated software to a customer that would not honor their contracts. It would suck to have found that out after several more months of program development.
  2. #32
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,731
    Just moved this thread to the Application Beta Testing forum since it contains relevant information.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
  3. #33
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Thanks, David. Here is where this thread belongs.
  4. #34
    Senior Member Jeff H's Avatar
    MEP 2011
    Oct 2010
    186
    I wish this would pickup more traction and would be very useful.
    The only thing I could think off adding would be to testing add-in loader, remover etc..... type tool that loaded first then copied or deleted whatever files needed. User had UI to select to update, remove, etc...
    You can also find your answers @ theswamp.org
  5. #35
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Quote Originally Posted by Jeff H View Post
    That’s interesting. A ‘Version Coordination’ program for long term beta development. Am I reading that correctly?
    That deserves some though. Substituting Dlls without the need for uninstall/reinstall would make the process easier on the tester. If the process could smoothed out and simplified, the general angst associated with using non-polished software would be diminished.
  6. #36
    MEP 2011
    Oct 2010
    186
    Here is something that I use at office and needs some additional functionality added but is not what was explained above but somewhat in same neighborhood.
    Quick summary is this goes plug-in folder and reads .loadconfig which tells it what directories to go and look for a .loaddata file. The .loadata file tells it what files to copy to its folder or overwrite if newer, then netload which dll's.
    So gives you chance to update files before netloaded and could be refactored to go online on exit to get updates, and delete from plug-in and update folder if user decides to remove.
    The .loadconfig file tells the loader where the .loaddata
    loaddata file
    Code:
    <?xml version="1.0" encoding="utf-8" ?>
    <AddInLoaderData CopySubDirectories ="false" ExtensionFilter =".dll|.cuix|.mnr">
      <LoadFiles>
         <LoadFile>HpadCad.App.dll</LoadFile>
    	 <LoadFile>HpadCad.SSM.dll</LoadFile>
      </LoadFiles>
    </AddInLoaderData>
    The xml file above basically tells it not to copy subdirectories, what extension a file must have to copy, and which files to netload.
    Code:
        public class Loader
            static readonly string loadDataFileName = "HpadCadAddInLoaderData.loadData";
            static readonly string loadConfigFileName = "HpadCadAddinLoader.loadconfig";
            private Dictionary<FileSystemInfo, SystemException> exceps = new Dictionary<FileSystemInfo, SystemException>();
            private readonly Editor _ed;
            private readonly DirectoryInfo _netLoaderDirectoryPath;
            internal DirectoryInfo NetLoaderDirectoryPath
                get
                    return _netLoaderDirectoryPath;
            public Loader()
                _netLoaderDirectoryPath = new DirectoryInfo(Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location));
            public void Load()
                try
                    Copy();
                finally
                    foreach (var systemException in exceps)
                        //Ed.WriteMessage("\n{0} had {1]", systemException.Key.FullName, systemException.Value.Message);
            private void Copy()
                FileInfo loadconfigFile = GetFilePathFromAddinLoaderDirectory(loadConfigFileName);
                if (!loadconfigFile.Exists)
                    return;
                var xconfigDoc = XElement.Load(loadconfigFile.FullName);
                var updateDirectoryAttribute = xconfigDoc.Attribute("UpdateDirectory");
                if (updateDirectoryAttribute == null)
                    return;
                var updateDirectory = ExpandDirectoryPath(updateDirectoryAttribute.Value);
                if (!updateDirectory.Exists)
                    return;
                FileInfo updateDataFile = CombineFileNameAndDirectoryPath(loadDataFileName, updateDirectory);
                if (!updateDataFile.Exists)
                    return;
                var xDataDoc = XElement.Load(updateDataFile.FullName);
                var copySubsAttribute = xDataDoc.Attribute("CopySubDirectories");
                bool copySubs = false;
                if (copySubsAttribute != null)
                    copySubs = Convert.ToBoolean(copySubsAttribute.Value);
                var extensionFiltersAttribute = xDataDoc.Attribute("ExtensionFilter");
                var extensionFilters = new HashSet<string>();
                if (extensionFiltersAttribute != null)
                    var filter = extensionFiltersAttribute.Value;
                    if (!String.IsNullOrWhiteSpace(filter))
                        extensionFilters = new HashSet<string>(filter.Split('|'), StringComparer.OrdinalIgnoreCase);
                exceps = CopyFiles(updateDirectory, NetLoaderDirectoryPath, extensionFilters, copySubs);
                foreach (var loadFile in xDataDoc.Descendants("LoadFile"))
                    var assemblyFI = GetFilePathFromAddinLoaderDirectory(loadFile.Value);
                    Assembly.LoadFrom(assemblyFI.FullName);
            private Dictionary<FileSystemInfo, SystemException> CopyFiles(DirectoryInfo sourceDirectory, DirectoryInfo destinationDirectory, ICollection<string> extensionFilters, bool copySubDirectories)
                var exceptions = new Dictionary<FileSystemInfo, SystemException>();
                return CopyFiles(sourceDirectory, destinationDirectory, extensionFilters, copySubDirectories, exceptions);
            private Dictionary<FileSystemInfo, SystemException> CopyFiles(DirectoryInfo sourceDirectory, DirectoryInfo destinationDirectory, ICollection<string> extensionFilters, bool copySubDirectories, Dictionary<FileSystemInfo, SystemException> exceptions)
                if (!destinationDirectory.Exists)
                    try
                        destinationDirectory.Create();
                    catch (IOException ex)
                        exceptions.Add(destinationDirectory, ex);
                    catch (SecurityException se)
                        exceptions.Add(destinationDirectory, se);
                foreach (var fi in sourceDirectory.GetFilteredFiles(extensionFilters))
                    FileInfo newFile = new FileInfo(Path.Combine(destinationDirectory.FullName, fi.Name));
                    if (!newFile.Exists)
                        try
                            fi.CopyTo(newFile.FullName);
                            exceptions.Add(newFile, ex);
                            exceptions.Add(newFile, se);
                    else if (fi.LastWriteTimeUtc > newFile.LastWriteTimeUtc)
                        try
                            fi.CopyTo(newFile.FullName, true);
                if (copySubDirectories)
                    foreach (var subDi in sourceDirectory.EnumerateDirectories())
                        var tempDI = new DirectoryInfo(Path.Combine(destinationDirectory.FullName, subDi.Name));
                        CopyFiles(subDi, tempDI, extensionFilters, true, exceptions);
                return exceptions;
            private DirectoryInfo ExpandDirectoryPath(string unExpandedPath)
                return new DirectoryInfo(Environment.ExpandEnvironmentVariables(unExpandedPath));
            private FileInfo GetFilePathFromAddinLoaderDirectory(string fileName)
                return new FileInfo(Path.Combine(NetLoaderDirectoryPath.FullName, fileName));
            private FileInfo CombineFileNameAndDirectoryPath(string fileName, string directoryName)
                return new FileInfo(Path.Combine(directoryName, fileName));
            private FileInfo CombineFileNameAndDirectoryPath(string fileName, DirectoryInfo directoryInfo)
                return CombineFileNameAndDirectoryPath(fileName, directoryInfo.FullName);
    Oh yeah will need this one
    Code:
        public static class DirectoryInfoExtensions
            internal static IEnumerable<FileInfo> GetFilteredFiles(this DirectoryInfo sourceDirectory,
                ICollection<string> extensions)
                if (extensions.Count == 0)
                    return sourceDirectory.EnumerateFiles();
                return sourceDirectory.EnumerateFiles().Where(fi => extensions.Contains(fi.Extension));
    What this allows me to do is to add a build to the solution that output folder is on the network and next time user starts autocad they will get latest build unless they have another instance running then will get it when that start next with no other instances locking files
  7. #37
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Thanks Jeff. I'll be sure to look into everything you posted above. A nice, natural progression, though not something I had previously considered.
  8. #38
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Neat idea, Jeff - As usual.
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  1. Sign Up for Navisworks Beta Testing
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 10th Dec 2013, 10:00 pm
  2. 3D Injector (Beta testing)
    By jgabase in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd May 2012, 02:57 pm
  3. Join the Beta Testing for AutoCAD Ironman
    Last Post: 22nd Nov 2010, 08:10 pm
  4. DWF Viewer Beta Testing Opportunity
    Last Post: 5th Dec 2006, 03:21 am
