basty Posted January 16, 2015 Share Posted January 16, 2015 How to justifying middle and center a text in Acad 2014? I can only do is center alignment. How to do the middle? Quote Link to comment Share on other sites More sharing options...
nestly Posted January 16, 2015 Share Posted January 16, 2015 The Justify tools inside the text editor change the justification of selected text relative to the width of the mtext object. I believe "Middle Center" is only available as a justification for the insertion point of the entire mtext object. (I use the Properties Palette) Quote Link to comment Share on other sites More sharing options...
Dana W Posted January 16, 2015 Share Posted January 16, 2015 Click on the "A" button under the textstyle name. That list is the full range of justification options, regardless of the insertion point. These options justify the entire contents of the text box without having to highlight any particular part of the text itself. It is another way of accessing the options in the Justify row of the properties pallet. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 17, 2015 Share Posted January 17, 2015 A good rule of thumb is that if you are justifying the entire text object is to use the properties pallet. If you are justifying only a part of the text, use the toolbar. Quote Link to comment Share on other sites More sharing options...
rkent Posted January 18, 2015 Share Posted January 18, 2015 Look to the left on the bottom line of icons, there is an A with a drop down arrow, you can do it there. Quote Link to comment Share on other sites More sharing options...
Dana W Posted January 19, 2015 Share Posted January 19, 2015 Methinks Elvis has left the room. Quote Link to comment Share on other sites More sharing options...
