AutoLisp for compiling of block attributes from csv file
nicodam84
Hi
i'm looking for an Autolisp that help me to compile title block starting from a csv file. At the moment I know this Lisp
http://www.lee-mac.com/updatetitleblock.html
It is exactly what I need. The problem is that this program compile all the block title (present in "model" sheet) with the first line of the csv file.
So all the block title will be equal.
I need a routine that -for example- compile 5 block with attribute taking information from 5 different line of the csv file. This has to be done in "model" area.
Does exist some progrma that colud be ok for this ??
Tnx in advance
Nicola
  • Replies 23
  • nicodam84
    12
  • BIGAL
    6
  • Tharwat
    6
Post a dwg and csv, sounds like you need a more specific lisp that just does your task, reading a csv is easy, updating a block is easy, the only hard part here is that your titles are all in model space so you need to advise of the desired method of the order picking line 1 is this title, and so on. If you had them as layouts its much easier to match with out user input.
Had a look at this need to start maybe with Lee-mac ReadCSV this will make a list that can be looked at line by line. Then its just a case of using a double repeat to update the block. It would allow manual picking of the block for the order etc. Will see if I can find time if some one else does not do first.
I have taken a different approach to this problem and are putting forward a fits all type of solution it will work with any block any number of attributes rather than just doing one that only works for you block only.
Ok do this for any one else as well this is the intended method the numbers represent each variable pulled from the csv file.
;Copy next line to command line
(setq x 0)
; copy next line to command line and pick blocks.
(foreach att (vlax-invoke (vlax-ename->vla-object (car (entsel))) 'getattributes)(vla-put-textstring att (setq x (+ x 1))))
Here is a working version note the CSV is true comma seperated value file for testing you can change the "," to ";" for semicolon.
Note actual code is after Lee-mac routines.
Change (setq j 1) to skip 1st line
DWG,LAYOUT,LOC,SIGLA,REPARTO,CODICE_SIECAB,CODICE_DTR,CODIFICA,PALL
EX,MODEL,1,2,3,4,5,6,7
EX,MODEL,8,9,10,12,13,14
EX,MODEL,15,16,17,18,19,20,21
EX,MODEL,22,23,2,4,25,26,27,28
;; Read CSV  -  Lee Mac
;; Parses a CSV file into a matrix list of cell values.
;; csv - [str] filename of CSV file to read
(defun LM:readcsv ( csv / des lst sep str )
   (if (setq des (open csv "r"))
           (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
           (while (setq str (read-line des))
               (setq lst (cons (LM:csv->lst str sep 0) lst))
           (close des)
   (reverse lst)
;; CSV -> List  -  Lee Mac
;; Parses a line from a CSV file into a list of cell values.
;; str - [str] string read from CSV file
;; sep - [str] CSV separator token
;; pos - [int] initial position index (always zero)
(defun LM:csv->lst ( str sep pos / s )
   (cond
       (   (not (setq pos (vl-string-search sep str pos)))
           (if (wcmatch str "\"*\"")
               (list (LM:csv-replacequotes (substr str 2 (- (strlen str) 2))))
               (list str)
       (   (or (wcmatch (setq s (substr str 1 pos)) "\"*[~\"]")
               (and (wcmatch s "~*[~\"]*") (= 1 (logand 1 pos)))
           (LM:csv->lst str sep (+ pos 2))
       (   (wcmatch s "\"*\"")
           (cons
               (LM:csv-replacequotes (substr str 2 (- pos 2)))
               (LM:csv->lst (substr str (+ pos 2)) sep 0)
       (   (cons s (LM:csv->lst (substr str (+ pos 2)) sep 0)))
(defun LM:csv-replacequotes ( str / pos )
   (setq pos 0)
   (while (setq pos (vl-string-search  "\"\"" str pos))
       (setq str (vl-string-subst "\"" "\"\"" str pos)
             pos (1+ pos)
   str
(setq csvlst (LM:readcsv "C:\\temp\\test.csv"))
(setq len (length csvlst))
(setq j 0) ;Change (setq j 1) to skip 1st line
(repeat len
(setq sublist (nth J csvlst))
(setq x -1)
(setq x (+ x 1))
(vla-put-textstring att (nth x sublist))
(setq j (+ J 1))
) ; len
hi Bigal
i can't run your lisp (present in second answer). Could you send me the file (.lsp) to load in dwg ??
other question: csv file must change or not ??
tnx a lot for your help
hi Bigal
Just open Notepad and copy and paste save as csvtoblock.lsp use Appload to run it.
look for this in code your data has ;
Hi
I try run the program, but when I appload it, autocad say to me
Comando: (LOAD "C:/Users/nicola.dambrosio/Desktop/csvtoblock.lsp") nil
i don't understand if is still necessary run Lee Mac before
tnx
Try this program and keep the Excel file in the same directory where the drawing is though I can modify the program to allow the user to select the Excel file if you want to .
Let me know how you get on with it .
(defun c:Upatts
      (/ _doc _peel:string fl o st tag v lst ss i sn p att str)
;;;    Author: Tharwat Al Shoufi    ;;;
;;;    Date: 22.01.2015        ;;;
 (defun _peel:string (str del / pos lst)
   (while (setq pos (vl-string-search del str 0))
     (progn (setq lst (cons (substr str 1 pos) lst))
            (setq str (substr str (+ pos 2) (strlen str)))
   (if (and str (/= str ""))
     (setq lst (cons str lst))
   (setq lst (reverse lst))
 (if (and (setq fl
                 (findfile (strcat (getvar 'DWGPREFIX) "Cartel1.csv"))
          (setq o (open fl "r"))
     (setq st (read-line o))
     (setq tag (cddr (_peel:string st ";")))
     (while (setq st (read-line o))
       (setq v   (_peel:string st ";")
             lst (cons (list (car v) (cadr v) (cddr v)) lst)
     (close o)
     (vla-startundomark
       (setq _doc (vla-get-ActiveDocument (vlax-get-acad-object)))
     (if (setq ss
                (ssget
                  "_X"
                  (list
                    '(0 . "INSERT")
                    '(66 . 1)
                    (cons
                      2
                      (apply 'strcat
                             (mapcar '(lambda (x) (strcat x ","))
                                     (mapcar 'car lst)
         (setq sn (ssname ss (setq i (1- i))))
         (if
           (vl-some
             '(lambda (x)
                (and
                  (eq (strcase (cdr (assoc 2 (entget sn))))
                      (strcase (car x))
                  (eq (strcase (cdr (assoc 410 (entget sn))))
                      (strcase (cadr x))
                  (setq att x)
             lst
            (mapcar
              '(lambda (a)
                 (if
                   (and (setq p (vl-position (vla-get-tagstring a) tag))
                        (setq str (nth p (caddr att)))
                    (vla-put-textstring a str)
              (vlax-invoke
                (vlax-ename->vla-object sn)
                'getattributes
     (vla-endundomark _doc)
)(vl-load-com)
(c:Upatts)
Edited by Tharwat
Open your drawing that contains the attributed blocks that listed in the excel file .csv then load the lisp with the use of appload command .
The command name is Upatts and it should run automatically without and user intervention .
How do you expect from the program to work since that the block name is not listed ( included ) in the Excel file ?
Beside that , the second column should obtain the space name ( Model/layout )
Besides all of that , your last attached files are completely different than the one you uploaded earlier .
Hi
Sorry I didn't know this. in which column is necessary put thhe block name ??
Beside that , the second column should obtain the space name ( Model/layout )?
First I tried with csv file with Model/layout in second column but it still doesn't work, than I changed it tryng to do something different (bad idea I suppose)
I load the original csv file, but i really dont' know where I have to insert column with block name
https://www.dropbox.com/sh/k8cupww37ubo1z0/AAA_m3haxsPv2jZG8hTOkXtMa?dl=0
As you probably understood i'm a beginner with lisp; thanks for all contribution you kindly are giving me
ND
I updated the codes above and just add the program to your acaddoc.lsp and put the following excel file in the same location where
the drawing is located .
Note: you can update the Excel file as per the sequence of the data .
Cartel1.csv
hi
now it works
I knew LEE MAC lisp that works similar
yours is faster because automatically load csv file. I'm lokking for something that without update the Excel file as per the sequence of the data.
For example: csv file with 100 different line that update dwg eith 100 block
do you think is it possible (maybe adding some loop function in the script) ??
Tnx a lot
