vernonlee Posted January 20, 2015 Share Posted January 20, 2015 Looking for a hatch lisp to window select multiple closed polylines & hatch them at once but result in individual hatch objects, base on current hatch settingd. Came across this code but was it unable to base on current hatch settings (defun c:mhatch (/ ang do-it doc hatch oname pname scl space ss) (if (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE")))) (progn (setq scl (getvar "hpscale") ang (getvar "hpang") pname (getvar "hpname") hpassoc (if (= (getvar "hpassoc") 1) :vlax-true :vlax-false) doc (vla-get-activedocument (vlax-get-acad-object)) space (if (= (getvar "cvport") 1) (vla-get-paperspace doc) (vla-get-modelspace doc) ) ) (vlax-for ent (vla-get-activeselectionset doc) (setq do-it nil oname (strcase (vla-get-objectname ent))) (cond ((vl-string-search "CIRCLE" oname) (setq do-it t) ) ((and (vl-string-search "LINE" oname) (eq (vla-get-closed ent) :vlax-true) ) (setq do-it t) ) ((equal (vlax-curve-getstartpoint ent) (vlax-curve-getendpoint ent) 1e-6) (setq do-it t) ) ) (if do-it (progn (setq hatch (vlax-invoke space 'addhatch acHatchObject pname hpassoc)) (vlax-invoke hatch 'appendouterloop (list ent)) (vlax-put hatch 'patternangle ang) (vlax-put hatch 'patternscale scl) (vla-evaluate hatch) ) ) ) ) ) (princ) ) Thanks Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 20, 2015 Share Posted January 20, 2015 Hi, I have just wrote this program and added to my Lisp-box (defun c:Test (/ h _doc ss) ;;; Tharwat 20.01.2014 ;; (princ "\n Select closed objects to hatch as per current hatch settings ") (if (setq _doc (vla-get-activedocument (vlax-get-acad-object)) ss (ssget '((-4 . "<OR") (0 . "CIRCLE,ELLIPSE") (-4 . "<AND") (0 . "LWPOLYLINE") (-4 . "&=") (70 . 1) (-4 . "AND>") (-4 . "OR>")))) (vlax-for o (vla-get-activeselectionset _doc) (setq h (vlax-invoke (vla-get-block (vla-get-activelayout _doc)) 'addhatch acHatchObject (getvar "hpname") (if (= (getvar "hpassoc") 1) :vlax-true :vlax-false))) (vlax-invoke h 'appendouterloop (list o)) (vlax-put h 'patternangle (getvar "hpang")) (vlax-put h 'patternscale (getvar "hpscale")) (vla-evaluate h) ) ) (princ) )(vl-load-com) Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 20, 2015 Author Share Posted January 20, 2015 (edited) Hi Tharwat. Tested it & somehow it will not follow current setting which is non associative. When using the LISP to hatch, it still hatch as associative. Any advise on this? Thanks Edited January 20, 2015 by vernonlee Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 20, 2015 Share Posted January 20, 2015 It seems that the parameter for the association is not making any sense with the use of the vlax-invoke function Try this instead and let me know (defun c:Test (/ soc h _doc ss) ;;; Tharwat 20.01.2014 ;; (princ "\n Select closed objects to hatch as per current hatch settings ") (if (setq _doc (vla-get-activedocument (vlax-get-acad-object)) soc (if (= (getvar "hpassoc") 1) :vlax-true :vlax-false) ss (ssget '((-4 . "<OR") (0 . "CIRCLE,ELLIPSE") (-4 . "<AND") (0 . "LWPOLYLINE") (-4 . "&=") (70 . 1) (-4 . "AND>") (-4 . "OR>")))) (vlax-for o (vla-get-activeselectionset _doc) (setq h (vlax-invoke (vla-get-block (vla-get-activelayout _doc)) 'addhatch acHatchObject (getvar "hpname") soc)) (vlax-invoke h 'appendouterloop (list o)) (vla-put-AssociativeHatch h soc) (vlax-put h 'patternangle (getvar 'hpang)) (vlax-put h 'patternscale (getvar 'hpscale)) (vla-evaluate h) ) ) (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 20, 2015 Author Share Posted January 20, 2015 (edited) Hi Tharwat. I now works. But i realised some of the polylines are not closed but look close (did not know there was such a thing), which the normal hatch command can select. Could you include those that can be selected by normal hatch command? Thanks Edited January 20, 2015 by vernonlee Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 20, 2015 Share Posted January 20, 2015 Why you are quoting every reply ? just a simple reply is more than enough if you don't reply to a specific point , remove the two programs from your replies please to keep the thread 's representation looking good at least . Could you include those that can be selected by normal hatch command? Replace my selection set function with yours . eg. (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE")))) with the highlighted codes ONLY . (setq _doc (vla-get-activedocument (vlax-get-acad-object)) soc (if (= (getvar "hpassoc") 1) :vlax-true :vlax-false) [color="red"] ss (ssget '((-4 . "<OR") (0 . "CIRCLE,ELLIPSE") (-4 . "<AND") (0 . "LWPOLYLINE") (-4 . "&=") (70 . 1) (-4 . "AND>") (-4 . "OR>")))[/color] ) Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 20, 2015 Author Share Posted January 20, 2015 Roger. Will clean up my previous post. Did the code replacement & i got this error when i load the lisp ; error: malformed list on input my code after replacement is this (defun c:Test (/ soc h _doc ss) ;;; Tharwat 20.01.2014 ;; (princ "\n Select closed objects to hatch as per current hatch settings ") (if (setq _doc (vla-get-activedocument (vlax-get-acad-object)) soc (if (= (getvar "hpassoc") 1) :vlax-true :vlax-false) (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE")))) ) (vlax-for o (vla-get-activeselectionset _doc) (setq h (vlax-invoke (vla-get-block (vla-get-activelayout _doc)) 'addhatch acHatchObject (getvar "hpname") soc)) (vlax-invoke h 'appendouterloop (list o)) (vla-put-AssociativeHatch h soc) (vlax-put h 'patternangle (getvar 'hpang)) (vlax-put h 'patternscale (getvar 'hpscale)) (vla-evaluate h) ) ) (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 20, 2015 Share Posted January 20, 2015 No , Read this modification and compare it with your last reply . (defun c:Test (/ soc h _doc ss) ;;; Tharwat 20.01.2014 ;; (princ "\n Select closed objects to hatch as per current hatch settings ") (if (setq _doc (vla-get-activedocument (vlax-get-acad-object)) soc (if (= (getvar "hpassoc") 1) :vlax-true :vlax-false) ss (ssget '((0 . "LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))) ) (vlax-for o (vla-get-activeselectionset _doc) (setq h (vlax-invoke (vla-get-block (vla-get-activelayout _doc)) 'addhatch acHatchObject (getvar "hpname") soc)) (vlax-invoke h 'appendouterloop (list o)) (vla-put-AssociativeHatch h soc) (vlax-put h 'patternangle (getvar 'hpang)) (vlax-put h 'patternscale (getvar 'hpscale)) (vla-evaluate h) ) ) (princ) )(vl-load-com) Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 20, 2015 Author Share Posted January 20, 2015 Ok. I guess as much I did something wrong. Will compare them to see where I went wrong when I am back in office tomorrow & test the code as well. Will feedback then. Thanks again bro. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 20, 2015 Share Posted January 20, 2015 Good luck Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 21, 2015 Author Share Posted January 21, 2015 Hi Tharwat. Tested it & had this error. Also not all selected objects are hatched. Out of 25 selected, only 6 are hatched. Command: TEST Select closed objects to hatch as per current hatch settings Select objects: Specify opposite corner: 25 found Select objects: Hatch boundary associativity removed. Hatch boundary associativity removed. Hatch boundary associativity removed. Hatch boundary associativity removed. Hatch boundary associativity removed. Hatch boundary associativity removed.; error: AutoCAD.Application: Invalid input Command: Hatch boundary associativity removed. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 21, 2015 Share Posted January 21, 2015 That error took a place due to selecting open objects . Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 21, 2015 Author Share Posted January 21, 2015 Tested it further & yes that is correct. If there is an open object within the selected, that error will occur. Will play around with the 2 lisp to see which fits me better. Thanks again Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 21, 2015 Share Posted January 21, 2015 Tested it further & yes that is correct. If there is an open object within the selected, that error will occur. And that's why I have changed the way of selecting objects before to avoid selecting open Polylines Quote Link to comment Share on other sites More sharing options...
BlackBox Posted January 21, 2015 Share Posted January 21, 2015 For those that may be interested... I just use this to select what I want to hatch, right click, and select Quick Hatch: Cheers Quote Link to comment Share on other sites More sharing options...
