Civil 3D 2015 Thick lines
JerryG
If your running 2015 you may have noticed that the Lines
appear to be thicker when you are zoomed out.
At first I thought it was showing my Linetype Thickness but that was not
the case.
2015 has a new setting called " Smooth Line Display"
When it is on the lines do indeed appear smoother but they also
appear thicker. Which for me was very annoying.
To turn of simply go to "Options"
"Graphics Performance"
and De-select "Smooth Line Display"
I'm not sure if it matters but
I am running a Nvidea Quadro FX 580 Graphics card with Autodesk recommended
driver - 9.18.13.3182
Hope this helps someone! 8)
