Inventor LT vs AutoCAD
brioche
Hello wise forum members,
At my very small company, we currently use AutoCAD LT 2008 (it’s ok to laugh). I would like to upgrade to a 3D product so I can produce 3D renderings as well as the occasional unfolded cone. I’m trying to decide whether to purchase Inventor LT Suite or AutoCAD (full version- not LT).
Here’s the conundrum:
Inventor LT Suite offers 3D and also can unfold a cone (I’m quite sure).
AutoCAD offers 3D, but cannot unfold a cone (based on my limited experience with a trial version).
So, Inventor LT Suite appears to be more powerful than AutoCAD, YET it is quite a bit less expensive. What am I missing here? I have visited the Autodesk site many times and my answers seem to be shrouded in mystery.
Also, and I hesitate to complicate matters, but the folks of this forum seem to be very knowledgeable…what about Solidworks? Should I be considering this program instead?
Thank you for your time- I appreciate any insight you can offer.
You're not missing anything here. AutoCAD has become an outdated program in many respects, where as Inventor is a newer, intuitive CAD application. The LT versions of the new brand of CAD software is miles ahead of even the full version of AutoCAD. If you want real power, then go ahead and jump up to a full version.
But as stated, you still get AutoCAD with suite packages so you can still fall back on what you're comfortable with while you engage in newer, better software. :)
LT is cheaper because some functionalities are not available that are in the Full versions.
AFAIK Inventor LT does not have Sheet Metal, which is what I believe you need to unfold a cone.
Key capabilities available in other software in the
Inventor software family that are not available
in Inventor LT include, but are not limited to, the
following:
• 3D assembly modeling
• Specialty tools such as sheet metal and dynamic
simulation
• Customization via application programming
interface (API) access or third-party add-in
applications
http://www.autodesk.com/products/inventor-lt-family/compare/compare-products
Did you give the Inventor LT a trial to see if it unfolds cones?
Unfortunately - you information is incorrect. LT will not unfold a cone - you need the full version of Inventor.
SolidWorks does not have an LT version. SolidWorks and Inventor are equivalent.
