ybx Posted January 21, 2015 Share Posted January 21, 2015 Dear members.... I am facing a problem in autocad when i open a file it is stuck with a messeg (Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.) and it will open after 50/60 seconds... AM ATTACHING HERE THE IMAGE Can anybody help me to solve this problem Thanks..... Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 21, 2015 Share Posted January 21, 2015 The fact that it is taking almost a minute to open is that what is of concern to you? Quote Link to comment Share on other sites More sharing options...
ybx Posted January 21, 2015 Author Share Posted January 21, 2015 The fact that it is taking almost a minute to open is that what is of concern to you? hi ReMark.... Thanks for ur reply The problem is i cant load any script file (autoscript) i need to press Esc button at every time some time it will hang for more than one minute.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 21, 2015 Share Posted January 21, 2015 You did not mention anything about a script in your initial post. Maybe you have a problem with the path to the script and AutoCAD is trying to sort through it. Quote Link to comment Share on other sites More sharing options...
ybx Posted January 21, 2015 Author Share Posted January 21, 2015 You did not mention anything about a script in your initial post. Maybe you have a problem with the path to the script and AutoCAD is trying to sort through it. no..when am not using any script then also this message will display and hang autocad Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 21, 2015 Share Posted January 21, 2015 Have you considered that it might be a problem with the drawing itself? When did the problem first present itself? What is the source of the drawing? What is the file size of the drawing? Quote Link to comment Share on other sites More sharing options...
ybx Posted January 21, 2015 Author Share Posted January 21, 2015 Have you considered that it might be a problem with the drawing itself? When did the problem first present itself? What is the source of the drawing? What is the file size of the drawing? Can you tell me what the value of the variable DWGCHECK is? This is not only the problem of one file if i open any file this will happen.. i think this is the problem from autocad am using (2014 and 2015) both same problem am using this from last 4 months but problem start on yesterday am used to with many lisp is this any problem of virus?... Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 21, 2015 Share Posted January 21, 2015 What makes you think it might be a virus? So we have two different versions of AutoCAD and both experience delays in opening drawings. Is that correct? And when did this first become noticeable? Have you made any hardware or software changes recently? Are you on a network? Quote Link to comment Share on other sites More sharing options...
ybx Posted January 21, 2015 Author Share Posted January 21, 2015 What makes you think it might be a virus? So we have two different versions of AutoCAD and both experience delays in opening drawings. Is that correct? And when did this first become noticeable? Have you made any hardware or software changes recently? Are you on a network? yes ..net worked ..there are other system in my office but no problem for them Quote Link to comment Share on other sites More sharing options...
ybx Posted January 21, 2015 Author Share Posted January 21, 2015 am not made any hardware or software changes.. two different versions of AutoCAD and both experience delays ..yes this is licensed versions also.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 21, 2015 Share Posted January 21, 2015 So this problem only affects you. Have you downloaded any lisp routines lately? Have you tried closing AutoCAD and shutting down your computer then waiting 20 seconds, booting back up, then opening/testing AutoCAD? Have you installed service pack 1 for 2015? Quote Link to comment Share on other sites More sharing options...
ybx Posted January 21, 2015 Author Share Posted January 21, 2015 Have you tried closing AutoCAD and shutting down your computer then waiting 20 seconds, booting back up, then opening/testing AutoCAD? k.. i will try this and let u know.. thanks Quote Link to comment Share on other sites More sharing options...
ybx Posted January 22, 2015 Author Share Posted January 22, 2015 Hi.. i could see one lisp is generating automatically in folder when i open any file from folder in that folder an automatically a lisp file is creating lisp name (acaddoc.lsp) i think this is the problem for hang how to avoid this Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 22, 2015 Share Posted January 22, 2015 The fact that this lisp is generating multiple copies of acaddoc.lsp in multiple folders means you have a virus. I think it is the acad.vlx virus. See post #8 of this thread....http://www.cadtutor.net/forum/showthread.php?58117-acad-viruse&highlight=acad.vlx Quote Link to comment Share on other sites More sharing options...
ybx Posted January 22, 2015 Author Share Posted January 22, 2015 do you have any idea to remove this Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 22, 2015 Share Posted January 22, 2015 Read this....http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-detect-and-remove-the-Acad-vlx-virus-s.html?v=2013 Quote Link to comment Share on other sites More sharing options...
ybx Posted January 22, 2015 Author Share Posted January 22, 2015 k...will let you know Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 22, 2015 Share Posted January 22, 2015 k...will let you know Look at post #16. Quote Link to comment Share on other sites More sharing options...
