script that loads lisps
ybx
Hi..All
How to write a simple script that loads lisps from a network location
without adding it is in the startup suit. (location is added in support file search path) Can anyone help me out with that?
Thanks!....
Put all your common lisps in the support directory that you have added, like Lee above add mini defuns so you can load lisp at any time as a command
; yourlisp.lsp
(defun C:ZE () (command "zoom" "E"))
(defun c:39 () (Setvar "osmode" 39))
(defun c:xfp () (load "xfallper.lsp"))
Thanks..for your reply
I tried this (load "//T:/Documents/my folder/Lisps/Etr.lsp" nil)
in script but its not working it shows Command: etr
Unknown command "ETR". Press F1 for help.
my drive---T
Path-----Documents \my folder\Lisps
Lisp-------etr.lsp
comand----(defun c:Etr ()
I already added T drive in support directory
Can you correct me
Thanks
hi
at the end it is working
when i put this code in script it is working
(defun c:etr () (load "etr.lsp"))
etr
etr
etr
why should i add ETR three times (am not expert in script and lisp) if it is wrong way pls correct me...
Thanks
You need to edit etr.lsp so it has the c:etr then as you have the support path set you can just do (load "etr")(c:etr)
Hi....
Thanks for ur great support..
It is running
Thanks
