move a object to a specified coordinate
anindya
i have many section like that which i have to shift the fully section to the mentioned datum means Y=MENTIONED DATUM and X =0 so every time i have to see what datum is there that is time taking so it would be easier if any lisp is available to shift it fully just by clicking there.
You can get the Y number from the text only problem is you have two numbers in the text Lee-mac has a parse numbers but it will find the front not the back number, the way to go is to read the text backwards till you get the space STA 70 DATUM 51.000 is 0 0 0 . 1 5 space then reverse 51.000. I dont have anything to do that. Any one ?
This is really a part 2 of your other post, once you get that working then this request would be part of it. The bigger picture is the problem a long and cross section routine from excel data.
