Penn Foster Civil Project, check
Hondatek
i'm Not too sure on these instructions.
• Before you can draw the contours of the land, you’ll need
to locate all the surveyed spot elevations on your drawing.
The surveyors gathered 216 spot elevations. The spot
elevations, taken at equal distances apart, run across the
length of the surveyed area in 12 evenly spaced rows.
1. Create Layer Spot (color yellow, linetype continuous)
on which to draw the elevation values.
2. Create an X using two intersecting lines, each 10
feet long, on Layer Spot. The lines should intersect
at their midpoints.
3. MOVE the lines from the intersection of the lines
(using the Osnap) to the center of the benchmark
(again using the Osnap).
4. Now, use the ARRAY command. When the command
prompt asks you to select objects, enter P for
previous. (AutoCAD will automatically select the
two lines you had just moved.) Use a rectangular
array with 12 rows and 18 columns. When
AutoCAD prompts you for the unit distance
between rows, enter –50. (You enter a negative
number since you’re arraying the rows from the
northwest corner to the lower portion of the screen,
which is a negative direction in AutoCAD.) When
between rows, enter 50. (This time, you’ll enter a
positive number since you’re arraying columns
from the northwest corner to the right, which in
AutoCAD is a positive direction.) Finally, ERASE the
spot elevation mark that you had positioned with
the benchmark.
5. Create a text style named SPOT-TEXT. Select
ROMANS as the font, and use a height of 6″ and a
width factor of 0.8. While still in Layer Spot, use
the DTEXT command and type XXX alongside the
spot elevation mark in the lower-left corner of the
screen. Now, use the ARRAY command again to copy
the XXX to alongside all the rest of the spot
elevations.
Civil
see #4 it says rows twice not rows then columns.
this is the screen shot.
and AutoCad propts are different then what PF are saying in this project.
this is how i did it Remark.
Command: _arrayrect
Select objects: 1 found
Select objects: 1 found, 2 total
Select objects:
Type = Rectangular Associative = Yes
Select grip to edit array or [ASsociative/Base point/COUnt/Spacing/COLumns/Rows/Levels/eXit]: R
Enter the number of rows or [Expression] : 12
Specify the distance between rows or [Total/Expression] : -50
Specify the incrementing elevation between rows or [Expresson] :
Select grip to edit array or [ASsociative/Base point/COUnt/Spacing/COLumns/Rows/Levels/eXit]: COL
Enter the number of columns or [Expression] : 18
Specify the distance between columns or [Total/Expression] : 50
you can pick what to do next.
The different prompts you are seeing as compared to what Penn-Foster says is probably due to the fact that the instructions have not been updated to reflect changes in the ARRAY command. P-F is using the old command which is still available if one knows how to access it via the command line.
