IG design Posted January 31, 2015 Share Posted January 31, 2015 Hi there... ...I'm having a problem with this and I'm not sure it is possible to solve this as it is on the pic in attachment. I need to create pattern on curved surface, and the body which has to be patterned has also irregular shape . Pls, help me with this...I'm desperate. I'm sending you pic in attachment...it's that sole network Thanks! Quote Link to comment Share on other sites More sharing options...
Pablo Ferral Posted January 31, 2015 Share Posted January 31, 2015 In AutoCAD?! Quote Link to comment Share on other sites More sharing options...
IG design Posted January 31, 2015 Author Share Posted January 31, 2015 No, no....in Solidworks...2013...sorry, i haven't mentioned... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 31, 2015 Share Posted January 31, 2015 As an Autocad answer I guess similar in solid works you create a roller coaster pattern use it as a path to extrude a tube, array it in two directions and you have the mesh pattern clip edges to the shoe shape. The edge tubes similar but a bit more difficult need to place and array around edge. If the shoe is curved then placing the roller coaster tubes will require a bit more effort but achiveable. Quote Link to comment Share on other sites More sharing options...
