Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 44
  1. #11
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Hi Greg, thanks for testing this for me.
    Ideally, with the use of the .Bundle format, a user would not have to Netload anything. Autodesk has set up the process such that any bundle found in a couple of specific locations (one being C:\Users\UserName\AppData\Roaming\Autodesk\ApplicationPlugins) would have the pertinent DLLs loaded automatically (either at startup or upon command invocation).
    What happens if you type T2G, without using the netload command?
  2. #12
    Senior Member GP_'s Avatar
    AutoCAD 2017
    Oct 2010
    Vercelli, Italy
    307
    Quote Originally Posted by SEANT View Post
    This is a 2015 upgrade to an existing app...
    Thank you Seant, works fine.
  3. #13
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Good to hear, GP_.
    I did not get to it in a timely manner, but thanks for the promo here:
    http://www.cadtutor.net/forum/showth...l=1#post622640
    Incidentally, I'll be beta testing a 2015 update for that UV Vector Mapping routine shortly.
  4. #14
    Senior Member troggarf's Avatar
    troggarf's Computer Details
    Windows 8.1
    AutoCAD 2016
    Oct 2010
    Littleton, Co
    193
    Sean,
    It is working now.
    The reason I was using net load was because I usually see a pop up saying that such-n-such plug-in has loaded and I didn't it when I copied your .bundle into its Application plugins folder.
    However, your ribbon panel did show up in the Add-ins ribbon. So I clicked on the icon and then got the error saying "Unknown command: _t2g"...
    So that is why I went ahead and used netload.
    I think that I simply needed to restart AutoCAD again for it to fully kick in. All is good now.
    But now you have to make one work for 2016 before it gets released. HAHA
    Thanks again,
    ~Greg
    ~Greg B
    Have fun!! www
  5. #15
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Quote Originally Posted by troggarf View Post
    I know. I've got to work harder/faster, lest I fall too far behind.
    I'm glad to hear you're up and running once again.
  6. #16
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,595
    I was able to install on 2015 and it is working without any problems. I have only used it a few times so far.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  7. #17
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    So far, so good. With an impending Autodesk upgrade right around the corner, it may make sense to hold off re-submitting 'til then.
  8. #18
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    The Text to Geometry beta routine I have here can also be run in AutoCAD 2016 with a simple file switch. The file:
    Local Disk(C) - Users - <User Name> - AppData - Roaming - Autodesk - ApplicationPlugins - STSC_TextToGeometry.bundle - PackageContents.xml
    must be replaced by the similarly named file in the attached ZIP.
  9. #19
    Forum Newbie
    AutoCAD 2015
    Mar 2015
    1
    Hey!
    I ve got a problem whit this Zip archives, I dunno what should i do(?? after exact ?? )... should i copy somewhere or it is more complicated???
    I hope you will able to help me although I m not a computer scientist, but an AutoCAD fanatic.
    Hope you help: -G-
  10. #20
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Quote Originally Posted by girgultesa View Post
    Actually, it is that simple. The STSC_TextToGeometry.bundle folder should be placed in the Autodesk - ApplicationPlugins folder.
    See this thread for more details:
    http://www.cadtutor.net/forum/showth...-an-App.Bundle
  1. Text figures as geometry and tool bar size
    By Quik&Easy in forum AutoCAD Beginners' Area
    Last Post: 27th Nov 2010, 12:04 am
  2. Geometry analysis for text and blocks using AutoCAD
    By ewan_m in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Mar 2010, 08:09 pm
  3. Geometry in Text
    By ankitcs in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2007, 02:12 am
  4. Geometry in Text
    By ankitcs in forum Autodesk Software General
    Last Post: 19th Oct 2007, 05:20 pm
  5. EXPLODING TEXT TO GEOMETRY
    By dangermouse in forum AutoCAD Beginners' Area
    Last Post: 7th May 2007, 08:30 pm
