Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 44
  1. #21
    Forum Newbie
    Mechanical 2015
    Apr 2015
    4
    I am receiving unknown command for T2G. App is loaded and icon is there but still receiving that when I try to use in 2015.
  2. #22
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,462
    That's odd. I actually developed/debugged via Mechanical 2015.
    Could you try to load the program explicitly by NETLOADing:
    . . . . \ApplicationPlugins\STSC_TextToGeometry.bundle\Con tents\Support\STSC_Text2Geom_v19.dll
    Does it still give the same "Unknown Command" response?
  3. #23
    Forum Newbie
    Mechanical 2015
    Apr 2015
    4
    I used the netload command and afterwards I was able to type and use the text 2 geometry application. When I went to specify an insert point I was given a fatal error and CAD shut down.
    "FATAL ERROR: Unhandled Access Violation Reading 0X0000 Exception at ed569f74h"
    Error report contains following files : acminidump.dmp, dmpuserinfo.xml, dumpdata.zip
    Let me know if there is anything I can do to help, I am kind of new to all of this but always willing to get down and into it.
  4. #24
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,462
    Damn, that sounds bad. So the STSC_TextToGeometry.bundle is properly placed, but does not load the CUI, nor Dll. The Dll is loadable, but causes fatal exception.
    Yikes. I hope it is just a corrupt download. In that light, perhaps you could delete the current Bundle file, and re-download/install.
    In case that isn't the problem, do you recall the specifics of the Text to Geometry call? what font were you using? What settings were invoked; specifically, was "As Regions" checked?
  5. #25
    Forum Newbie
    Mechanical 2015
    Apr 2015
    4
    The bundle is properly placed, appdata-roaming-autodesk-applicationPlugins. I was using Vladamir Script and Technic are the only 2 fonts I tried. I will download and replace again and see if that works.
  6. #26
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,462
    I can confirm that the add-in can work in Mechanical 2015, though that does not guarantee much . Hopefully a re-install will help.
    I don't have the Vladamir font, but Technic works okay.
  7. #27
    Forum Newbie
    Mechanical 2015
    Apr 2015
    4
    After re installing it seems to work for me. I don't know why because I had tried that earlier but, oh well seems to be working fine for me. Thanks Sean!
  8. #28
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,462
    Very good to hear. Thanks for your perseverance.
  9. #29
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,462
    Here is a re-package - to include support for AutoCAD 2016 based products.
    See this thread for manual loading instructions:
    http://www.cadtutor.net/forum/showth...-an-App.Bundle
    It is quite possible that the code module (STSC_Text2Geom_v19.dll) will need to be unblocked. If so, see this page for instructions:
    http://www.thewindowsclub.com/unblock-file-windows-8
  10. #30
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by SEANT View Post
    Mine is very similar; presuming the .ZIP file is unblocked first, the resultant files *should* all be unblocked as well (regardless of manual, or registry/context menu alternatives):
    Code:
    Windows Registry Editor Version 5.00
    [HKEY_CLASSES_ROOT\*\shell\powershell]
    @="Unblock Files"
    "Extended"=""
    "HasLUAShield"=""
    "Position"="Bottom"
    [HKEY_CLASSES_ROOT\*\shell\powershell\command]
    @="C:\\Windows\\system32\\WindowsPowerShell\\v1.0\\powershell.exe Unblock-File -LiteralPath '%L'"
    Separately, one can also apply any given context menu to one or more specific HKCR\Folder; example:
    Code:
    [HKEY_CLASSES_ROOT\Folder\shell\Unblock FOO]
    @="Unblock FOO"
    "AppliesTo"="System.ItemPathDisplay:\"Downloads\" OR System.ItemPathDisplay:\"Documents\""
    "HasLUAShield"=""
    "Position"="Bottom"
    [HKEY_CLASSES_ROOT\Folder\shell\Unblock FOO\command]
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  1. Text figures as geometry and tool bar size
    By Quik&Easy in forum AutoCAD Beginners' Area
    Last Post: 27th Nov 2010, 12:04 am
  2. Geometry analysis for text and blocks using AutoCAD
    By ewan_m in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Mar 2010, 08:09 pm
  3. Geometry in Text
    By ankitcs in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2007, 02:12 am
  4. Geometry in Text
    By ankitcs in forum Autodesk Software General
    Last Post: 19th Oct 2007, 05:20 pm
  5. EXPLODING TEXT TO GEOMETRY
    By dangermouse in forum AutoCAD Beginners' Area
    Last Post: 7th May 2007, 08:30 pm
