Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 44 of 44
  1. #41
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,455
    Regrettably, my enthusiasm for code maintenance, at least as it applies to the exchange postings, has waned a bit. And the Text To Geometry app was the catalyst. For some Windows 7 based systems that app would crash, and take AutoCAD with it.
    The Autodesk Exchange testers were able to reproduce the crash on one of their test setups, and the app was rightfully pulled from the store. After the Exchange reported it to me, I set up a separate system with Windows 7, but could never reproduce the crash. Neither could most of the people I've corresponded with, windows 7 or otherwise.
    I don't doubt that a problem exists - it's just tough to debug an issue that can't be experienced. I suspect it has something to do with 'permissions' and how that particular App stores settings between use.
    All that aside, I have let the other apps slide as well. Despite some newer projects that have captivated my attention, I've got to get my butt back in gear to update what's already on the shelves.
  2. #42
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    I can completely relate - I've had several customers need assistance, only in my case, to find out that Autodesk unilaterally changed PackageContents.xml, or my help files without even so much as notifying me (I had to trouble shoot it myself to find out).
    In any event, I'm glad that you've made a good choice for your situation, and hope it improves moving forward, my friend.
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  3. #43
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,455
    Quote Originally Posted by BlackBox View Post
    . . . . that Autodesk unilaterally changed PackageContents.xml, or my help files without even so much as notifying me . . . .
    Yikes! Their making the decision to pull an app from the shelves is one thing, that's something else entirely.
    As a matter of fact, I think they should make a point to avoid meddling at the app level. They should insist that the app developer make corrections. Perhaps pull the app, if necessary. I'm sure they have plenty of issues at the Autodesk application level to keep their developers busy.
    I will acknowledge that the Exchange is more likely dealing with a ''mission critical' state than the average App Store. As such, the balance of all things may be more complex. Hopefully a few more years of experience will make everything run more smoothly.
    Keep plugging away, mon ami. I'll do the same.
  4. #44
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,020
    The printer is not working, is it turned on, yes, lights on, yes, Check correct printer chosen, yes, sure its plugged in, yes, please double check, yes, check the status of prints pending on printer, I have no idea, oh sorry some one has kicked the printer cable slightly out working now. Will the App store pull the software because it wont print ?
  1. Text figures as geometry and tool bar size
    By Quik&Easy in forum AutoCAD Beginners' Area
    Last Post: 27th Nov 2010, 12:04 am
  2. Geometry analysis for text and blocks using AutoCAD
    By ewan_m in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Mar 2010, 08:09 pm
  3. Geometry in Text
    By ankitcs in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2007, 02:12 am
  4. Geometry in Text
    By ankitcs in forum Autodesk Software General
    Last Post: 19th Oct 2007, 05:20 pm
  5. EXPLODING TEXT TO GEOMETRY
    By dangermouse in forum AutoCAD Beginners' Area
    Last Post: 7th May 2007, 08:30 pm
