Andrew1979 Posted February 2, 2015 Share Posted February 2, 2015 I have a program that usually runs fine. However, on an AutoCAD drawing that is 4mb in size of just 2D linework, the program slows to a crawl. It can take almost 2minutes to do a really basic rectangle (i tested) So I used the animate function in the AutoLISP IDE and have found that when a certain function is called, it just takes forever. The code where this happens is below: (defun dimEuting () (command "-dimstyle" "RESTORE" "EUTING" "dim" "dimsah" "on" "dimfxlon" "off" "dimtxsty" "Arial" "DIMTXT" "3.0" "dimasz" "3.0" "dimblk" "archtick" "dimblk1" "archtick" "dimblk2" "archtick" "dimtfill" "1" "dimldrblk" "." "dimdle" "0" "dimdli" "2.0" "dimexe" "1.0" "dimexo" "1.0" "dimgap" "1.0" "dimscale" "50" "dimfxlon" "off" "save" "EUTING" "y" "exit" "-dimstyle" "RESTORE" "EUTING" "-dimstyle" "a" "all" "") ) Can anyone see any glaring issues with this piece of code and why in a certain sized drawing this becomes an issue? Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted February 4, 2015 Share Posted February 4, 2015 You can use setvar instead for some lines of your code. Quote Link to comment Share on other sites More sharing options...
Andrew1979 Posted February 4, 2015 Author Share Posted February 4, 2015 ok, thanks for that. Didn't even occur to me to use setvar. I will give it a try and see if it helps. Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted February 5, 2015 Share Posted February 5, 2015 ok, thanks for that. Didn't even occur to me to use setvar. I will give it a try and see if it helps. You are welcome. Quote Link to comment Share on other sites More sharing options...
Ahankhah Posted February 5, 2015 Share Posted February 5, 2015 Here you can find variables related to dimension: Command: SETVAR Enter variable name or [?] <>: ? Enter variable(s) to list <*>: dim* DIMADEC 0 DIMALT OFF DIMALTD 2 DIMALTF 25.4000 DIMALTRND 0.0000 DIMALTTD 2 DIMALTTZ 0 DIMALTU 2 DIMALTZ 0 DIMANNO 0 (read only) DIMAPOST "" DIMARCSYM 0 DIMASO ON DIMASSOC 2 DIMASZ 0.1800 DIMATFIT 3 DIMAUNIT 0 DIMAZIN 0 DIMBLK "" DIMBLK1 "" DIMBLK2 "" DIMCEN 0.0900 DIMCLRD 0 DIMCLRE 0 DIMCLRT 0 DIMDEC 4 DIMDLE 0.0000 DIMDLI 0.3800 DIMDSEP "." DIMEXE 0.1800 DIMEXO 0.0625 DIMFIT 3 DIMFRAC 0 DIMFXL 1.0000 DIMFXLON OFF DIMGAP 0.0900 DIMJOGANG 45 DIMJUST 0 DIMLDRBLK "" DIMLFAC 1.0000 DIMLIM OFF DIMLTEX1 "" DIMLTEX2 "" DIMLTYPE "" DIMLUNIT 2 DIMLWD -2 DIMLWE -2 DIMPOST "" DIMRND 0.0000 DIMSAH OFF DIMSCALE 1.0000 DIMSD1 OFF DIMSD2 OFF DIMSE1 OFF DIMSE2 OFF DIMSHO ON DIMSOXD OFF DIMSTYLE "Standard" (read only) DIMTAD 0 DIMTDEC 4 DIMTFAC 1.0000 DIMTFILL 0 DIMTFILLCLR 0 DIMTIH ON DIMTIX OFF DIMTM 0.0000 DIMTMOVE 0 DIMTOFL OFF DIMTOH ON DIMTOL OFF DIMTOLJ 1 DIMTP 0.0000 DIMTSZ 0.0000 DIMTVP 0.0000 DIMTXSTY "Standard" DIMTXT 0.1800 DIMTXTDIRECTION OFF DIMTZIN 0 DIMUNIT 2 DIMUPT OFF DIMZIN 0 DIMCONSTRAINTICON 3 Quote Link to comment Share on other sites More sharing options...
