toberino Posted February 2, 2015 Share Posted February 2, 2015 (edited) Hello all, I have a very monotonous task of cleaning up my backgrounds sent from architects prior to designing the structure. Currently to select the hatches properly and only the ones that I want to delete I have to invoke the quick select, select hatch from the object type, then scale, then type the scale from the properties, and then the value (which is usually 1, 24, 42, 70) depending on which arch I get them from and how they set up their plans. I would like to automate this task and select all of the different scales in one swoop (lisp). And maybe even delete them too. Anyone have a routine that does something like this? Here is the bottom line; What I am trying to acheive is a routine that I only have to run once. That will, unlock all of the layers turn on all of the layer thaw all of the layers delete all of the sheets detach all of the xref's select and delete certain hatches based off of their pattern scale. (because select similar does not work) AND.....set layer to "0" and insert a point on location 0,0,0:shock: AND...PURGE everything ....and -PURGE everything.... So..just a small request is all. Don't be Okay, I got the first five steps. So far it will unlock, turn on, and thaw. And it will delete the sheets and detach the xref's. The hatch is probably going to be the one to stump me. :D:D:D:D:D Looks like it will be an SSGET for the hatching. Now to get the filtering right. Edited February 3, 2015 by toberino Quote Link to comment Share on other sites More sharing options...
ttray33y Posted February 3, 2015 Share Posted February 3, 2015 (edited) Hello all,I have a very monotonous task of cleaning up my backgrounds sent from architects prior to designing the structure. Currently to select the hatches properly and only the ones that I want to delete I have to invoke the quick select, select hatch from the object type, then scale, then type the scale from the properties, and then the value (which is usually 1, 24, 42, 70) depending on which arch I get them from and how they set up their plans. I would like to automate this task and select all of the different scales in one swoop (lisp). And maybe even delete them too. Anyone have a routine that does something like this? Here is the bottom line; What I am trying to acheive is a routine that I only have to run once. That will, unlock all of the layers turn on all of the layer thaw all of the layers delete all of the sheets detach all of the xref's select and delete certain hatches based off of their pattern scale. (because select similar does not work) AND.....set layer to "0" and insert a point on location 0,0,0:shock: AND...PURGE everything ....and -PURGE everything.... So..just a small request is all. Don't be Okay, I got the first five steps. So far it will unlock, turn on, and thaw. And it will delete the sheets and detach the xref's. The hatch is probably going to be the one to stump me. :D:D:D:D:D Looks like it will be an SSGET for the hatching. Now to get the filtering right. (defun C:test(/ ent count) (setvar "cmdecho" 0) (setq ent(ssget "X" (list(cons 0 "HATCH")(cons 41 [b][i]13[/i][/b])))) ;; line above change 13 with the value of your hatch (if (and ent (> (sslength ent) 0)) (progn (setq count(sslength ent)) (command "ERASE" ent "") (command "-xref" "D" "*" "") (command "-layer" "U" "*" "T" "*" "set" "0" "") (command "-purge" "all" "*" "n") ;;reserve for removal of sheet (i have no idea) (alert (strcat "Erased " (itoa count) " Entities.")) ) ) (setvar "cmdecho" 1) (princ) ) (princ "\n Type test.") (princ) try this bro, however i have no idea how to delete sheet(s), also i'm not sure about "insert point" part. Edited February 3, 2015 by ttray33y Quote Link to comment Share on other sites More sharing options...
toberino Posted February 3, 2015 Author Share Posted February 3, 2015 (defun C:test(/ ent count) (setvar "cmdecho" 0) [color="red"] (setq ent(ssget "X" (list(cons 0 "HATCH")(cons 41 [b][i]13[/i][/b])))) ;; line above change 13 with the value of your hatch (if (and ent (> (sslength ent) 0)) (progn (setq count(sslength ent)) (command "ERASE" ent "")[/color] (command "-xref" "D" "*" "") (command "-layer" "U" "*" "T" "*" "set" "0" "") (command "-purge" "all" "*" "n") ;;reserve for removal of sheet (i have no idea) (alert (strcat "Erased " (itoa count) " Entities.")) ) ) (setvar "cmdecho" 1) (princ) ) (princ "\n Type test.") (princ) try this bro, however i have no idea how to delete sheet(s), also i'm not sure about "insert point" part. Awesome!!!! I have a couple of questions...see red above. Is that all of the hatch portion? I can piece things together but lack the brain power currently to force myself to learn it. I figured out the delete all sheets part. (vl-load-com) (defun C:DELETESHEETS () (vlax-for Layout (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (if (/= (vla-get-Name Layout) "Model") (vla-Delete Layout) ) ) ) I would like to narrow down the portion of the hatching so that I can get it modified just right for all of the hatches. Quote Link to comment Share on other sites More sharing options...
ttray33y Posted February 3, 2015 Share Posted February 3, 2015 Awesome!!!! I have a couple of questions...see red above. Is that all of the hatch portion? I can piece things together but lack the brain power currently to force myself to learn it. I figured out the delete all sheets part. (vl-load-com) (defun C:DELETESHEETS () (vlax-for Layout (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (if (/= (vla-get-Name Layout) "Model") (vla-Delete Layout) ) ) ) I would like to narrow down the portion of the hatching so that I can get it modified just right for all of the hatches. a short answer yes, oh i so you wanted to delete layout.. ehehehe Quote Link to comment Share on other sites More sharing options...
toberino Posted February 3, 2015 Author Share Posted February 3, 2015 (defun C:test(/ ent count) (setvar "cmdecho" 0) (setq ent(ssget "X" (list(cons 0 "HATCH")(cons 41 [b][i]13[/i][/b])))) ;; line above change 13 with the value of your hatch (if (and ent (> (sslength ent) 0)) (progn (setq count(sslength ent)) (command "ERASE" ent "") (command "-xref" "D" "*" "") (command "-layer" "U" "*" "T" "*" "set" "0" "") (command "-purge" "all" "*" "n") ;;reserve for removal of sheet (i have no idea) (alert (strcat "Erased " (itoa count) " Entities.")) ) ) (setvar "cmdecho" 1) (princ) ) (princ "\n Type test.") (princ) try this bro, however i have no idea how to delete sheet(s), also i'm not sure about "insert point" part. Okay. New question. Eliminating all of the "other" stuff, including the alert. Would you be so kind to only show the hatch selection and not delete it in the end? I will have multiple hatch scales (1, 2, 24, 42, etc.) that I would like to also be selected at the same time. I have OCD so I need to see what has been selected prior to hitting the delete key so I would like it to only select all of them in one command and then I will delete after I have verified the correct selections. Thanks again for the help! Quote Link to comment Share on other sites More sharing options...
ttray33y Posted February 3, 2015 Share Posted February 3, 2015 Okay. New question.Eliminating all of the "other" stuff, including the alert. Would you be so kind to only show the hatch selection and not delete it in the end? I will have multiple hatch scales (1, 2, 24, 42, etc.) that I would like to also be selected at the same time. I have OCD so I need to see what has been selected prior to hitting the delete key so I would like it to only select all of them in one command and then I will delete after I have verified the correct selections. Thanks again for the help! just remove "X" including quotes (setq ent(ssget [color="red"]"X"[/color] (list(cons 0 "HATCH")(cons 41 13)))) Quote Link to comment Share on other sites More sharing options...
toberino Posted February 3, 2015 Author Share Posted February 3, 2015 (edited) So here is what I have scrapped together so far.....and it works. I am sure it is not the most efficient code but it works. It seems to just blast through the routine so a couple of pauses to slow it down may be in order at some point. Maybe a break after selecting the hatches and an approval to delete would be neat. And a approval for the purge too. But this can be done later. (Defun C:ArchWipe () (command "-LAYER" "U" "*" "") (Command "-Layer" "On" "*" "") (Command "-Layer" "Thaw" "*" "On" "*" "") (command "-layer" "U" "*" "T" "*" "set" "0" "") (vlax-for Layout (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (if (/= (vla-get-Name Layout) "Model") (vla-Delete Layout) ) ) ) (ssget "X" (list (cons 0 "HATCH"))) (setq sset (ssget "P")) (sssetfirst sset sset) (princ) ) (command "ERASE" ent "") (command "-xref" "D" "*" "") (command "-purge" "all" "*" "n") ) When I invoke this routine inside the Block Editor it returns a message that says "Converting (command) calls to (command-s) is recommended." and it does not run the routine. Is it just as simple as adding the -s and would it work the same? And, I just noticed something else now. The hatch selection doesn't always happen during the routine and when I come out of the appload dialog it starts up immediately and select all of the hatches. Something is definitely out of order. Thanks ttray33y for the quick throw together of some code to get me going. Edited February 3, 2015 by toberino Quote Link to comment Share on other sites More sharing options...
ttray33y Posted February 3, 2015 Share Posted February 3, 2015 So here is what I have scrapped together so far.....and it works. I am sure it is not the most efficient code but it works. It seems to just blast through the routine so a couple of pauses to slow it down may be in order at some point. Maybe a break after selecting the hatches and an approval to delete would be neat. And a approval for the purge too. But this can be done later. (Defun C:ArchWipe () (command "-LAYER" "U" "*" "") (Command "-Layer" "On" "*" "") (Command "-Layer" "Thaw" "*" "On" "*" "") (command "-layer" "U" "*" "T" "*" "set" "0" "") (vlax-for Layout (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (if (/= (vla-get-Name Layout) "Model") (vla-Delete Layout) ) ) ) (ssget "X" (list (cons 0 "HATCH"))) (setq sset (ssget "P")) (sssetfirst sset sset) (princ) ) (command "ERASE" ent "") (command "-xref" "D" "*" "") (command "-purge" "all" "*" "n") ) When I invoke this routine inside the Block Editor it returns a message that says "Converting (command) calls to (command-s) is recommended." and it does not run the routine. Is it just as simple as adding the -s and would it work the same? And, I just noticed something else now. The hatch selection doesn't always happen during the routine and when I come out of the appload dialog it starts up immediately and select all of the hatches. Something is definitely out of order. Thanks ttray33y for the quick throw together of some code to get me going. (defun C:ArchWipe (/ ent ) (setvar "cmdecho" 0) (setq ent(ssget (list(cons 0 "HATCH")))) (if (and ent (> (sslength ent) 0)) (progn (command "-LAYER" "U" "*" "") (Command "-Layer" "On" "*" "") (Command "-Layer" "Thaw" "*" "On" "*" "") (command "-layer" "U" "*" "T" "*" "set" "0" "") ) ) (setvar "cmdecho" 1) (princ) (command "erase" ent "") (command "-xref" "D" "*" "") (vlax-for Layout (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (if (/= (vla-get-Name Layout) "Model") (vla-Delete Layout) ) ) (command "-purge" "all" "*" "n") ) (princ) purge wont work inside block editor. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 3, 2015 Share Posted February 3, 2015 (defun C:ArchWipe (/ ent ) (setvar "cmdecho" 0) (setq ent(ssget (list(cons 0 "HATCH")))) (if (and ent (> (sslength ent) 0)) (progn ............................ (setvar "cmdecho" 1) ....................... (command "-purge" "all" "*" "n") ) (princ) @ ttray33y , a few comments in general if you are interested and don't mind . You set the system variable cmdecho and reset it back in the wrong place besides that , you assumed that the user's setting for it is 1 and it could be zero . Your ssget function could be shortened as shown below besides that , you can include the if function with the ssget function instead of adding it below with many checks if the selection set is correct . One more advise is to include the filter of LOCKED layers with the ssget function since that intended to erase the selected objects or at any other modification that might be required . (if (setq ent (ssget "_:L" '((0 . "HATCH")))) ;;; ................ and so on Quote Link to comment Share on other sites More sharing options...
ttray33y Posted February 3, 2015 Share Posted February 3, 2015 @ ttray33y , a few comments in general if you are interested and don't mind . You set the system variable cmdecho and reset it back in the wrong place besides that , you assumed that the user's setting for it is 1 and it could be zero . Your ssget function could be shortened as shown below besides that , you can include the if function with the ssget function instead of adding it below with many checks if the selection set is correct . One more advise is to include the filter of LOCKED layers with the ssget function since that intended to erase the selected objects or at any other modification that might be required . (if (setq ent (ssget "_:L" '((0 . "HATCH")))) ;;; ................ and so on thanks for the heads-up. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 3, 2015 Share Posted February 3, 2015 thanks for the heads-up. Not a problem . I see that the title of the thread is to select hatches based on their scales , so to build on that request you need to use the DXF 41 as you may be interested to get info in this regard HERE Quote Link to comment Share on other sites More sharing options...
toberino Posted February 3, 2015 Author Share Posted February 3, 2015 Not a problem . I see that the title of the thread is to select hatches based on their scales , so to build on that request you need to use the DXF 41 as you may be interested to get info in this regard HERE That is where I started but once I found a routine that will select all hatches "only" with one command then I changed the direction of it. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 3, 2015 Share Posted February 3, 2015 That is where I started but once I found a routine that will select all hatches "only" with one command then I changed the direction of it. Best of luck , Do you still need any help with this thread ? Quote Link to comment Share on other sites More sharing options...
toberino Posted February 4, 2015 Author Share Posted February 4, 2015 Best of luck , Do you still need any help with this thread ? Busy day today. Yes. I still have test out what ttray33y posted but i won't be able to until tomorrow. Quote Link to comment Share on other sites More sharing options...
toberino Posted February 4, 2015 Author Share Posted February 4, 2015 So this is what I have and it is logical order of how the steps should proceed. It selects the hatches as I exit the appload dialog which it shouldn't do. I don't really know what to do or how to organize it to work properly. Can anyone help me out, please? (Defun C:ArchWipe () (command "-LAYER" "U" "*" "") (Command "-Layer" "On" "*" "") (Command "-Layer" "Thaw" "*" "On" "*" "") (command "-layer" "U" "*" "T" "*" "set" "0" "") (vlax-for Layout (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (if (/= (vla-get-Name Layout) "Model") (vla-Delete Layout) ) ) ) (ssget "X" (list (cons 0 "HATCH"))) (setq sset (ssget "P")) (sssetfirst sset sset) (princ) ) (command "ERASE" ent "") (command "-xref" "D" "*" "") (command "-purge" "all" "*" "n") ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 4, 2015 Share Posted February 4, 2015 So this is what I have and it is logical order of how the steps should proceed. It selects the hatches as I exit the appload dialog which it shouldn't do. I don't really know what to do or how to organize it to work properly. Can anyone help me out, please? You want to enable the user to select the needed hatches or you want to delete this part from the program ? Quote Link to comment Share on other sites More sharing options...
toberino Posted February 4, 2015 Author Share Posted February 4, 2015 You want to enable the user to select the needed hatches or you want to delete this part from the program ? I want it to select and delete the hatches please. But after I run the routine. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 4, 2015 Share Posted February 4, 2015 Replace the following . This (Defun C:ArchWipe () With this . (Defun C:ArchWipe (/ sset) And this . (ssget "X" (list (cons 0 "HATCH"))) (setq sset (ssget "P")) (sssetfirst sset sset) (princ) ) With this . (if (setq sset (ssget "_X" '((0 . "HATCH")))) (command "_.erase" [color=red]sset [/color]"") ) Quote Link to comment Share on other sites More sharing options...
toberino Posted February 4, 2015 Author Share Posted February 4, 2015 Replace the following . This (Defun C:ArchWipe () With this . (Defun C:ArchWipe (/ sset) And this . (ssget "X" (list (cons 0 "HATCH"))) (setq sset (ssget "P")) (sssetfirst sset sset) (princ) ) With this . (if (setq sset (ssget "_X" '((0 . "HATCH")))) (command "_.erase" ent "") ) (Defun C:ArchWipe (/ sset) (command "-LAYER" "U" "*" "") (Command "-Layer" "On" "*" "") (Command "-Layer" "Thaw" "*" "On" "*" "") (command "-layer" "U" "*" "T" "*" "set" "0" "") (vlax-for Layout (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (if (/= (vla-get-Name Layout) "Model") (vla-Delete Layout) ) ) ) (if (setq sset (ssget "_X" '((0 . "HATCH")))) (command "_.erase" ent "") ) [color="red"](command "ERASE" ent "")[/color] (command "-xref" "D" "*" "") (command "-purge" "all" "*" "n") ) So I should be able to erase the red above since it seems to be included in the ssget for the hatch.? Quote Link to comment Share on other sites More sharing options...
toberino Posted February 4, 2015 Author Share Posted February 4, 2015 It has created a loop on the appload dialog box. Weird. And it is not getting the hatches now. Quote Link to comment Share on other sites More sharing options...
