vernonlee Posted February 6, 2015 Share Posted February 6, 2015 I am facing this issue & i need to get to the bottom of this. It is an existing drawing. When i do a dimension base on existing style, & when i adjust the dim text position, it will change to a weird number. The existing dimension do not have this issue. Only the dimension I create. Why is that & how do i prevent it? Thanks Quote Link to comment Share on other sites More sharing options...
samifox Posted February 6, 2015 Share Posted February 6, 2015 Sound like u need to adjust the precision ftom 0.000 to 0 in the style Quote Link to comment Share on other sites More sharing options...
vernonlee Posted February 6, 2015 Author Share Posted February 6, 2015 Sound like u need to adjust the precision ftom 0.000 to 0 in the style how i create the dimension is check what dimension style the existing is & i select that style as current then create the dim. The dimension text came out 300 (which is correct) but after i shift the dim text it becomes 45000 (which is wrong). So this relates to precision? But i select current style! AM i doing something wrong? edit Both are having a precision of '0' Quote Link to comment Share on other sites More sharing options...
samifox Posted February 6, 2015 Share Posted February 6, 2015 In case u shift only the text the value shouldnt alter in any way. I would run a recover in that drawing Quote Link to comment Share on other sites More sharing options...
vernonlee Posted February 6, 2015 Author Share Posted February 6, 2015 In case u shift only the text the value shouldnt alter in any way. I would run a recover in that drawing Really? I am thinking it is due to certain setting or system variable or the way I select the dimension style. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 6, 2015 Share Posted February 6, 2015 Are you dimensioning in model space or in a layout? Attach a copy of the drawing to your next post and someone here will take a look at it. Quote Link to comment Share on other sites More sharing options...
samifox Posted February 6, 2015 Share Posted February 6, 2015 Afaik No sys var does this. Can upload this drawing? Quote Link to comment Share on other sites More sharing options...
vernonlee Posted February 6, 2015 Author Share Posted February 6, 2015 Are you dimensioning in model space or in a layout? Attach a copy of the drawing to your next post and someone here will take a look at it. Drawing in model. Dimension in paper. I am out of office already. Will post the dwg when back in office after the weekend. But hopefully someone knows what the issue is before that. Thanks Quote Link to comment Share on other sites More sharing options...
samifox Posted February 6, 2015 Share Posted February 6, 2015 Does it happand with other styles as well? Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 6, 2015 Share Posted February 6, 2015 Drawing in model. Dimension in paper. I am out of office already. Will post the dwg when back in office after the weekend. But hopefully someone knows what the issue is before that. Thanks That happens with paperspace dimensions a lot. It is changing from model to paper units when modified. Either the dimensions are non-associative, or they are not quite snapped to a model object, or both. Quote Link to comment Share on other sites More sharing options...
mikekmx Posted February 6, 2015 Share Posted February 6, 2015 That happens with paperspace dimensions a lot. It is changing from model to paper units when modified. Either the dimensions are non-associative, or they are not quite snapped to a model object, or both. ^^^ what Dana said. Your vp scale is 1:150? (45000/300=150) Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 6, 2015 Share Posted February 6, 2015 I moved your thread to the AutoCAD 2D Drafting, Object Properties & Interface Forum. Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 7, 2015 Share Posted February 7, 2015 Hmmm cough cough. Is it fixed, or at least are you on track to fix it? Quote Link to comment Share on other sites More sharing options...
vernonlee Posted February 7, 2015 Author Share Posted February 7, 2015 Does it happand with other styles as well? Basically I only tried the main style which is set for this whole dwg Quote Link to comment Share on other sites More sharing options...
vernonlee Posted February 7, 2015 Author Share Posted February 7, 2015 That happens with paperspace dimensions a lot. It is changing from model to paper units when modified. Either the dimensions are non-associative, or they are not quite snapped to a model object, or both. That may be partly it. So need advise what should the right setting be & the right way to do the dimension such that the text do not change. As mention, how I did the dimension is to select the style as current then do the dimension. So when I shift the text the value changes to 45000 I then use match properties to select the existing dimension then select mine dim to revert the value back to 300. Quote Link to comment Share on other sites More sharing options...
vernonlee Posted February 7, 2015 Author Share Posted February 7, 2015 ^^^ what Dana said. Your vp scale is 1:150? (45000/300=150) I believer so yes. Quote Link to comment Share on other sites More sharing options...
vernonlee Posted February 7, 2015 Author Share Posted February 7, 2015 Hmmm cough cough. Is it fixed, or at least are you on track to fix it? No clear direction as to what I am doing wrong as yet. Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 7, 2015 Share Posted February 7, 2015 There is a clear direction of investigation already pointed out to at least make the occurrence less frequent. Part 1: Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 7, 2015 Share Posted February 7, 2015 Part 2: If you are not using associative dimensions, the rest of this doesn't apply, and it is up to your hand and eyeballs. Paperspace dimensions and modelspace objects Do Not work well unless the dimensions are associative. Do you use osnap to set your dimensions? If so, do you have NODE selected as one of the snaps? If you do, then turn NODE off while setting dimensions. It will cause the dimensions to be associated to each other rather than your drawing geometry, which renders the associative function useless. More to come, waffles are ready. Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 7, 2015 Share Posted February 7, 2015 Part 3: When you zoom way in on your dimension grips, do you see this? Even associative dimensions don't help without the node being right on the geometry. If your precision level is set larger than the gap between the dimension node and your geometry, the dimension will still show the correct dimension, until in the case of paperspace dimensions they are manipulated in some way. Quote Link to comment Share on other sites More sharing options...
