Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2010
    Feb 2015
    2
    Default How to create various scale output of a given image file
    Hi! I have a 1:50000 jpeg image of a sample map and I wanted to create output images of 1:25000, 1:12500, 1:10000 and 1:5000. How can I do that without sacrificing the quality of the original file? Thank you in advance.
    Senior Member Spaj's Avatar
    Spaj's Computer Details
    Win 7
    ASUS P5K
    Intel E8400
    4096Mb
    MSI Nvidia GTX660 2GB
    OCZ RevoDrive 128GB
    WD Black 1TB
    Samsung 27" LCD
    Civil
    Civil 3D 2016
    Oct 2013
    South Africa
    144
    Hi
    Insert the image to a known scale in modelspace ie 1:1 and create paperspace veiwports at the required scales. Obviously as the scales increase ie 1:5000 the image will become more pixelated.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,135
    You may want to think about tiling the image as multiple imagEs to keep quality
    Forum Newbie
    AutoCAD 2010
    Feb 2015
    2
    Hi Spaj and BIGAL! Thanks for the quick reply. I was thinking of converting it into vector then apply the method that you suggested. Is this process better than directly re scaling the jpeg image?
    My sample image is 400 dpi, I think it will not be too pixelated if I will go for 1:5000 scale. Am I correct in my theory?
  5. #5
    Win 7
    ASUS P5K
    Intel E8400
    4096Mb
    OCZ RevoDrive 128GB
    WD Black 1TB
    Samsung 27" LCD
    Civil
    Civil 3D 2016
    Oct 2013
    South Africa
    144
    Hi
    What application do you intend to use to convert your map to vector format? Intrigued to see the results. I would say stick with the jpeg. If your 1:50000 map is 400dpi then a 1:5000 viewport is going to be 40dpi.
  1. Create mass output with the PUBLISH command
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 15th May 2013, 03:00 am
  2. unable to create output file
    By bartymic in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th May 2012, 11:01 am
  3. Replies: 4
    Last Post: 24th Apr 2010, 09:05 pm
  4. Render Abort-Inability to create output file?
    By TheOSUArchitect in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Oct 2009, 03:21 am
  5. Raster Image Output from AutoCAD
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 2nd Dec 2006, 08:30 pm
Tags for this Thread
