Results 1 to 5 of 5
    Forum Newbie
    MEP 2015
    Jan 2015
    9
    Default Or Statement Not Working
    I've made this script to adjust the extensions on our rectangular transition ducts but it doesn't want to work for me. Everything is fine if I keep it simple and leave out the " Or "Ductmate 35" " part but for this to work, I will need the or statement.
    Anyways, here's the script...
    Code:
    select item.cid
    	case 2
    		dim extin = item.dim[6].numvalue
    		dim extout = item.dim[7].numvalue
    		dim con1 = item.connector[1].value
    		dim con2 = item.connector[2].value
    		if ( con1 = ("TDC" or "Ductmate 35") ) and
    		(extin < 2 ) then
    		item.dim[6].value = 2
    		end if
    		if ( con2 = ("TDC" or "Ductmate 35") ) and
    		(extout < 2 ) then
    		item.dim[7].value = 2
    		end if
    		if ( con1 <> ("TDC" or "Ductmate 35") ) and
    		(extin < 0.5 ) then
    		item.dim[6].value = 0.5
    		end if
    		if ( con2 <> ("TDC" or "Ductmate 35") ) and
    		(extout < 0.5 ) then
    		item.dim[7].value = 0.5
    		end if
    		item.update()
    end select
    Can anyone spot the problem? I'm hoping its an embarrassingly simple one.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    In lisp you would need another pair of brakets I think its the same here if ((.........< 2)) then
    Forum Newbie
    MEP 2015
    Jan 2015
    9
    Do you mean it should look something like this?
    Code:
    ((extin < 2 )) then
    end if
    I don't think putting something into two sets of brackets ((X)) would change the logic of the statement. I tried it just to be safe and there was no change.
    Thanks for trying though
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Dont program with this type of code method try this
    Code:
    if (( con1 = ("TDC" or "Ductmate 35") ) and (extin < 2 )) then
  5. #5
    Forum Newbie
    MEP 2015
    Jan 2015
    9
    Thanks for the tip. That actually looks a lot better and I changed my script to use the same format. Unfortunately it didn't fix the problem, but I think I figured out what is happening.
    take a look at these two pieces of code...
    Code:
    		(extout < 2 ) then
    		end if
    ;;;which is followed by...
    		end if
    I think that the or statement may be working, but then I have a second line of code which is supposed to handle what happens if con2 does not equal TDC or Ductmate 35. I didn't take into account that this statement would be true whether the connector were TDC or Ductmate 35 because it can't be both. I probalby should of made that into an "and" statement.
    Still, that would take a slightly chunkier piece of code. Do you know how I could use an else statement for this? I tried a few variations but kept getting errors I couldn't understand/fix.
    This is what my script now looks like...
    Code:
    select item.cid
    	case 2
    		if (( con1 = ("TDC" or "Ductmate 35")) and (extin < 2 )) then
    		item.dim[6].numvalue = 2 elseif
    		extin < 0.5 then
    		item.dim[6].numvalue = 0.5
    		end if
    		if (( con2 = ("TDC" or "Ductmate 35")) and (extout < 2 )) then
    		item.dim[7].numvalue = 2 elseif
    		extout < 0.5 then
    		item.dim[7].numvalue = 0.5
    		end if
    		item.update()
    end select
    Can you spot any syntax errors in that last script?
    By the way, thanks for all of your help so far.
  1. condition/and statement help?
    By LosGirk in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Sep 2014, 07:15 pm
  2. Conditional Statement
    By uuoo10levi in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jan 2013, 05:23 am
  3. IF and COND - I need another statement...?
    By mrharris78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Dec 2012, 02:38 pm
  4. COND statement help
    By ssm-jt in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Mar 2012, 03:38 pm
  5. Conditional statement
    By ketongin in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Nov 2011, 02:51 pm
Tags for this Thread
