+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Forum Newbie
    Using
    MEP 2015
    Join Date
    Jan 2015
    Posts
    9
    Default Or Statement Not Working
    I've made this script to adjust the extensions on our rectangular transition ducts but it doesn't want to work for me. Everything is fine if I keep it simple and leave out the " Or "Ductmate 35" " part but for this to work, I will need the or statement.
    Anyways, here's the script...
    Code:
    select item.cid
    	case 2
    		dim extin = item.dim[6].numvalue
    		dim extout = item.dim[7].numvalue
    		dim con1 = item.connector[1].value
    		dim con2 = item.connector[2].value
    		if ( con1 = ("TDC" or "Ductmate 35") ) and
    		(extin < 2 ) then
    		item.dim[6].value = 2
    		end if
    		if ( con2 = ("TDC" or "Ductmate 35") ) and
    		(extout < 2 ) then
    		item.dim[7].value = 2
    		end if
    		if ( con1 <> ("TDC" or "Ductmate 35") ) and
    		(extin < 0.5 ) then
    		item.dim[6].value = 0.5
    		end if
    		if ( con2 <> ("TDC" or "Ductmate 35") ) and
    		(extout < 0.5 ) then
    		item.dim[7].value = 0.5
    		end if
    		item.update()
    end select
    Can anyone spot the problem? I'm hoping its an embarrassingly simple one.
  2. #2
    Quantum Mechanic
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,170
    Default
    In lisp you would need another pair of brakets I think its the same here if ((.........< 2)) then
  3. #3
    Forum Newbie
    Using
    MEP 2015
    Join Date
    Jan 2015
    Posts
    9
    Default
    Do you mean it should look something like this?
    Code:
    ((extin < 2 )) then
    end if
    I don't think putting something into two sets of brackets ((X)) would change the logic of the statement. I tried it just to be safe and there was no change.
    Thanks for trying though
  4. #4
    Quantum Mechanic
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,170
    Default
    Dont program with this type of code method try this
    Code:
    if (( con1 = ("TDC" or "Ductmate 35") ) and (extin < 2 )) then
  5. #5
    Forum Newbie
    Using
    MEP 2015
    Join Date
    Jan 2015
    Posts
    9
    Default
    Thanks for the tip. That actually looks a lot better and I changed my script to use the same format. Unfortunately it didn't fix the problem, but I think I figured out what is happening.
    take a look at these two pieces of code...
    Code:
    		(extout < 2 ) then
    		end if
    ;;;which is followed by...
    		end if
    I think that the or statement may be working, but then I have a second line of code which is supposed to handle what happens if con2 does not equal TDC or Ductmate 35. I didn't take into account that this statement would be true whether the connector were TDC or Ductmate 35 because it can't be both. I probalby should of made that into an "and" statement.
    Still, that would take a slightly chunkier piece of code. Do you know how I could use an else statement for this? I tried a few variations but kept getting errors I couldn't understand/fix.
    This is what my script now looks like...
    Code:
    select item.cid
    	case 2
    		if (( con1 = ("TDC" or "Ductmate 35")) and (extin < 2 )) then
    		item.dim[6].numvalue = 2 elseif
    		extin < 0.5 then
    		item.dim[6].numvalue = 0.5
    		end if
    		if (( con2 = ("TDC" or "Ductmate 35")) and (extout < 2 )) then
    		item.dim[7].numvalue = 2 elseif
    		extout < 0.5 then
    		item.dim[7].numvalue = 0.5
    		end if
    		item.update()
    end select
    Can you spot any syntax errors in that last script?
    By the way, thanks for all of your help so far.
Similar Threads
  1. condition/and statement help?
    By LosGirk in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Sep 2014, 07:15 pm
  2. Conditional Statement
    By uuoo10levi in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jan 2013, 05:23 am
  3. IF and COND - I need another statement...?
    By mrharris78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Dec 2012, 02:38 pm
  4. COND statement help
    By ssm-jt in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Mar 2012, 03:38 pm
  5. Conditional statement
    By ketongin in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Nov 2011, 02:51 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
