Wrapping part around cylinder with a draft
Onetafs
Hi! I've been having a problem for quite awhile now with this model, its a chair with a 4mm plywood sheet wrapped around the base of the chair. The plywood sheet act as a backrest for the chair.
Attach the *.ipt file here.
Your sketch does not appear to be on a plane tangent to the cone.
Not sure of the purpose of WorkPlane1?
Taper could be included in the Extrusion1 rather than add FaceDraft.
