SRSawmills Posted February 13, 2015 Share Posted February 13, 2015 Hello, I want to know what is the best way to upload an Autocad drawing Version 2002 to Facebook. Thank you! Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 13, 2015 Share Posted February 13, 2015 Couldn't you just create a jpg or png file and upload it? Quote Link to comment Share on other sites More sharing options...
SRSawmills Posted February 13, 2015 Author Share Posted February 13, 2015 Thank you for your reply! Yes, i did that by going to "Publish To Web" and converted to JPEG, but the drawing becomes blurry and difficult to read as i zoom in. Same problem i got by just copying and pasting it to FB. Rgds. Quote Link to comment Share on other sites More sharing options...
gofindsam Posted February 13, 2015 Share Posted February 13, 2015 Why don't you print it to PDF file format. That should make the drawing come out clear and sharp. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted February 13, 2015 Share Posted February 13, 2015 Why don't you print it to PDF file format. That should make the drawing come out clear and sharp. Have you actually tried this? I'm at work, so I cannot test it, but everything I've read says it is not possible to upload a pdf to Facebook. One of these options might work though: http://shmuelhoffmansblog.com/2012/06/19/how-to-post-a-pdf-to-your-facebook-page/ Quote Link to comment Share on other sites More sharing options...
tzframpton Posted February 13, 2015 Share Posted February 13, 2015 The best quality would be to plot to PDF, then import into a raster editor such as Photoshop or gIMP, then Save As a *.TIFF using the ZIP compression algorithm, which can then be uploaded to Facebook as a high-res image. Although, Facebook still compresses any image you upload, so there will still be some level of artifacts messing up the image. If image quality or higher resolution is not of concern, then a simple screen shot from a Plot Preview window into Paint would work too. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 13, 2015 Share Posted February 13, 2015 The real secret is to use a pixel resized plot window with fit this forces the pixel ratio to go up played with this problem for hours. I use something like a sheet size of 4000x3500 @ 200dpi Quote Link to comment Share on other sites More sharing options...
Murph_map Posted February 13, 2015 Share Posted February 13, 2015 By the time you find the resolution you want to display as an image you'll see that Face Book will tell you the file size is too large, and either crop it or not accept it. Quote Link to comment Share on other sites More sharing options...
