HELP! My material that is applied via bitmap is showing in view but not rendering
Nicole33
Hi,
I am ready to pull my hair out! I have applied custom material via a bitmap. HOWEVER, it will render the texture in grey scale if I uncheck the color tab under self illumination in the parent tab so I get a rendering of a gray colored brick wall for example...if I check the color box in the parent tab it shows the material in my sample window in color, I am able to scale it using the UVW map...etc, etc. It shows in my camera view in the correct scale and color but when I go to render, the finished product does not show AT ALL. It will not render! I have read numerous tutorials and I can not find the problem. If someone has a suggestion...please send it along!
