Results 1 to 3 of 3
    Forum Newbie
    3ds Max 2015
    Feb 2015
    1
    Default HELP! My material that is applied via bitmap is showing in view but not rendering
    Hi,
    I am ready to pull my hair out! I have applied custom material via a bitmap. HOWEVER, it will render the texture in grey scale if I uncheck the color tab under self illumination in the parent tab so I get a rendering of a gray colored brick wall for example...if I check the color box in the parent tab it shows the material in my sample window in color, I am able to scale it using the UVW map...etc, etc. It shows in my camera view in the correct scale and color but when I go to render, the finished product does not show AT ALL. It will not render! I have read numerous tutorials and I can not find the problem. If someone has a suggestion...please send it along!
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    You wouldn't happen to have "Material Override" enabled in your Render Setup > Processing tab would you?
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    Did you figure out what the problem was? I'm curious if the material override was the issue or if it was something else?
    Facebook:
  1. how do I change the material/image applied to an object AutoCAD 2012?
    By thethirddimension in forum Blocks, Images, Models & Materials
    Last Post: 16th Jul 2014, 09:21 am
  2. Ceiling Tile Material not showing on the drawing
    By JamFam in forum Architecture & ADT
    Last Post: 2nd Jan 2013, 05:53 am
  3. need help with applying a bitmap to a material slot!!!!
    By truedud in forum UVW Mapping, Textures & Materials
    Last Post: 8th Jul 2011, 08:21 pm
  4. Material not showing in render scene
    By stensq in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th May 2010, 02:40 pm
  5. Rendering Material question
    By marlon in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Apr 2009, 11:26 am
