doncwe Posted February 14, 2015 Share Posted February 14, 2015 I'm sorry if I'm asking an obvious question, but I can't find the answer. When I start AutoCad it goes to Drawing 1.dwg of which I have close to a blank screen and re-open the file I want to work on. Is it possible to have AC open to the blank screen or the last file I was working on. Either option would be good. Regards Don Wensrich Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 14, 2015 Share Posted February 14, 2015 (edited) Courtesy of forum member rkent: Change the variable STARTUP to 1. Courtesy of forum member rkmcswain: .... even if you startup AutoCAD and "drawing1.dwg" opens, it will close as soon as you open another drawing, provided DBMOD=0 in "drawing1.dwg". Edited February 14, 2015 by ReMark Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 14, 2015 Share Posted February 14, 2015 This is a work around save the example to notepad and save as cross.bat to a simple location like c:\temp, then just got to CMD lower left and type c:\temp\cross it will start Autocad and open the cross dwg. You must use " if the path or name has spaces in it. You could paste also as a shortcut to the desktop. "C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\acad.exe" c:\temp\cross.dwg or if you want to enter dwg name note must be full path eg cross c:\projects\dwg32 "C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\acad.exe" %1 Quote Link to comment Share on other sites More sharing options...
doncwe Posted February 20, 2015 Author Share Posted February 20, 2015 Thank you for your reply Quote Link to comment Share on other sites More sharing options...
