Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Super Member
    Sengna's Computer Details
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    519
    Default Change Lower case to upper case MLD text??
    Is it possible to change the multileader text from Lower case to upper case all at once? rather change one by one. Thanks
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,723
    Sounds like a lisp to me. The nearest alternative I can find is to select all of them, then open properties and click on the edit button in the text contents line. The Mtext editor will then cycle through all of them, but you will still have to highlight each text and change them manually. I was hoping matchprop would do it, but it does not.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    519
    Quote Originally Posted by Dana W View Post
    Yeah, i have to change one by one which was a pain, Match Prop won''t work for 2014 Autocad Version. I double click on the MLD text hightlight and right click--- Change case to UPPER. hope Lee mac can develope Lisp to help with this.
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,723
    Quote Originally Posted by Sengna View Post
    Yeah, but if you do it my way for the time being, it will at least automatically open the mtext editor for you at each one. one would think AutoDesk would attach a case change macro or something to the contents box on the properties dialog.
    If they are all the same word, you can do it with Find/Replace all at once.
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,021
    (strcase text) in lisp just need a few minutes to mod one
    Ok done now
    Code:
    (defun caps ( / ss len x objtext)
    (vl-load-com)
    (setq ss  (ssget "X" (list (cons 0 "Mtext,text"))))
    (setq x 0)
    (setq len (sslength ss))
    (repeat len
    (setq ent (ssname ss x))
    (setq objtext (vlax-ename->vla-object ent))
    (vla-put-textstring objtext (strcase (vla-get-textstring objtext)))
    (setq x (+ x 1))
    (caps)
  6. #6
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    519
    Quote Originally Posted by BIGAL View Post
    (strcase text) in lisp just need a few minutes to mod one I have but a bit busy at moment.
    Code:
    (vl-load-com)
    (setq x 0)
    (repeat len
    (setq x (+ x 1))
    (caps)
    Should i just type these code to the command prompt Bigal??? or just strcase??
  7. #7
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,723
    Hang on, he's gotta modify this one a little.
  8. #8
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,021
    Sorry thats the code copy it all to Notepad and save as a .lsp file use Appload to run.
    Post updated above
  9. #9
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    519
    Post updated above
    I know how to save these code on notepad but how do i upload it? do you have a screenshot.? thanks
  10. #10
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    I'm sure this has been covered before in one of your threads. Use the APPLOAD command to load the lisp routine into AutoCAD then type "caps" to start it.
  1. Change Case of MLeader Text Strings
    By harilalmn in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jun 2014, 07:24 pm
  2. System variable for upper case
    By Tyke in forum AutoCAD General
    Last Post: 11th Apr 2013, 01:32 pm
  3. title case, small case in attributes
    By rock1 in forum AutoCAD General
    Last Post: 10th Sep 2012, 02:11 pm
  4. Upper and lower case lettering
    By Coosbaylumber in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Apr 2009, 05:35 pm
  5. converting lower case text to to capital text
    By REIVAX in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2009, 11:36 am
Tags for this Thread
