Get point of when there are no entities selected.
Lee Chu Chu
I have this code:
(setq PT1 (getpoint))
(setq PT2 (getpoint PT1))
(command "LINE" PT1 PT2)
(command)
(setq obj1 (entget (entlast)))
       (setq ent (car (nentsel "\nSelect Entity: \n")))
(cond
	((/= ent nil)
		(setq obj2 (entget ent))
                       (command "chamfer" obj ent)
               ((= ent nil)
                       (setq PT3 (getpoint ent))
                       (command "LINE" PT2 PT3)
Its supposed to be able to draw a line when if there is no entity it draws the line up till that point where I tried to select the entity. However when I execute this code, it will state that I have an inappropriate data type. How should I modify the code to be able to draw the line from the last point to the point of which I tried to select an entity if an entity doesn't exist at that particular point?
i prefer IF statement (your code using cond)
example
(if ent
 (alert "Do chamfer")
 (alert "Draw line")
 ) ;_ end of if
Try this:
(defun c:test ( / pt1 pt2 obj1 ent PT3)
   (command "_LINE" "_non" PT1 "_non" PT2 "")
   (setq obj1 (entlast))
   (setq ent (entsel "\nSelect Entity: \n"))
   (setq PT3 (cadr (grread T)))
   (if ent
       (command "_chamfer" obj1 ent)
       (command "_LINE" "_non" PT2 "_non" PT3 "")
