Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Senior Member
    Manufacture
    BrianTFC's Discipline Details
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    188
    AutoCAD How do I center the text in the rectangle and repeat the last input?
    Hi All,
    I'm having a little trouble figuring out how to center my text in the middle of the rectangle after its created. Here's what I have so far, it works but it waits for me to place it. Also I do a lot of panels that are the same size so I also want the lisp to remember the last input so I can continue to use it until I hit escape or return.
    If I could get some help I would appreciate it.
    Code:
    (defun C:CRP7()
      (setq cmdold (getvar "cmdecho"))
      (setvar "cmdecho" 0)
      (setq PL (getstring "Enter a Panel Label :"))
      (setq PA (getpoint "Select Panel Area :"))
      (command "-boundary" "Advanced" "Island" "No" "Nearest" "" pa "")
      (command "_.change" (entlast) "" "_p" "_la" "Router - Green - V groove" "")
      (setq ts(getvar "textsize"))
      (setq tsty(getvar "textstyle"))
      (if(= 0 (cdr(assoc 40(tblsearch "style" tsty))))
      (command "text" "Justify" "Center" pa ts 0 PL)))
      (setvar "cmdecho" cmdold)
    Thanks Brian
    Super Member hmsilva's Avatar
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    Hi Brian,
    if you are not using AutoCAD 2015, try the following program.
    The 'bpoly' function, is generating an error in AC2015, (not sure why)...
    Change the default prompt "123" to a panel size.
    Code:
    (vl-load-com)
    (defun c:demo ( / adoc bp cen lays msp pa pl plo reg sfa txt)
      (setq adoc (vla-get-activedocument (vlax-get-acad-object))
            msp (vla-get-modelspace adoc)
            lays (vla-get-layers adoc)
      (vla-add lays "Router - Green - V groove")
      (while (and (setq pa (getpoint "\n Select Panel Area: "))
                  (setq pl (getstring (strcat "\nEnter a Panel Label <" (cond (*pl) ("123")) ">: "))
                        *pl (cond ((/= pl "") (strcase pl)) (*pl) ("123"))
                  (setq bp (bpoly pa))
          (setq plo (vlax-ename->vla-object bp)
                sfa (vlax-make-safearray vlax-vbObject '(0 . 0))
          (vla-put-layer plo "Router - Green - V groove")
          (vlax-safearray-put-element sfa 0 plo)
          (setq reg (car (vlax-safearray->list (vlax-variant-value (vla-addregion msp sfa))))
                cen (vlax-get reg 'centroid)
          (vla-delete reg)
          (setq txt (vla-AddText msp *pl (vlax-3D-point (trans cen 1 0)) (getvar 'TEXTSIZE)))
          (vla-put-alignment txt 10)
          (vla-put-textalignmentpoint txt (vlax-3D-point (trans cen 1 0)))
          (vla-put-rotation txt (angle (list 0 0)(getvar 'UCSXDIR)))
    Hope that helps
    Henrique
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,713
    Perhaps an alternative method if you entlast the bpoly then get 'coordinates then middle of 1st and 3rd is center point.
    Code:
    (defun getcoords (ent)
        (vlax-variant-value
          (vlax-get-property
        (vlax-ename->vla-object ent)
        "Coordinates"
    (defun co-ords2xy ()
    ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
    (setq numb (/ (length co-ords) 2))
    (setq I 0)
    (repeat numb
    (setq xy (list (nth (+ I 1) co-ords)(nth I co-ords) ))
    (setq coordsxy (cons xy coordsxy))
    (setq I (+ I 2))
    ) ; end repeat
    (setq co-ords (getcoords (entlast)))
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,247
    @ Henrique
    Don't you think with me that it is better to move the functions to a separate sub-function to get the Activedocument , ModelSpace , Layers collection then Adding a new layer out of the loop of the while function ?
    Regards
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,713
    Like Tharwat you will see in my code 2 defuns because I have 1 in my library lisp for std stuff that I use all the time. My post about civ3d lables opens the Aec database only defun in new code. Same Getval nice dcl for input. Its got to the stage where I need to go through all code and standardise.
  6. #6
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    Quote Originally Posted by Tharwat View Post
    @ Henrique
    Regards
    Hi Tharwat,
    of course you're right!
    The code at #3 was written with an 'if' function, when posted, I saw that the OP wanted the code in a loop, and I modified it (quick and dirty) to a 'while'...
    My primary goal was, trying to demonstrate to OP an alternative method, and above all, trying to pass the idea that we should validate the return data from a function, before submit that data to another function/command.
    Code in message #3 revised.
    Cheers
    Henrique
  7. #7
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,247
    Quote Originally Posted by hmsilva View Post
    Undoubtedly it's nice
  8. #8
    Full Member
    AutoCAD 2013
    Oct 2014
    63
    Hi
    please find the attached lisp.
    This is from lee mac.
    it's work fine
    thanks
    yathishkumar
  9. #9
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    Thank you Tharwat!
  10. #10
    Senior Member
    Manufacture
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    188
    Henrique,
    I'm using AutoCAD 2015, I just haven't gotten a chance to update my info on here. so how do we fix this?
    Thanks
    Brian
  1. Repeat user input until value is true
    By Andrew1979 in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Dec 2014, 02:00 pm
  2. How to center-align a rectangle to a group/block?
    By BWCAD in forum AutoCAD Beginners' Area
    Last Post: 9th Nov 2012, 06:55 am
  3. Make a rectangle centered around center point?
    By kingneptune117 in forum AutoCAD Beginners' Area
    Last Post: 21st Jun 2012, 05:38 pm
  4. how do I repeat last input
    By mfranke in forum AutoCAD General
    Last Post: 23rd Nov 2007, 07:56 pm
  5. Need lisp to Align text to middle center of a box/rectangle?
    By Ste1978 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Nov 2007, 03:56 pm
Tags for this Thread
