How do I center the text in the rectangle and repeat the last input?
BrianTFC
Hi All,
I'm having a little trouble figuring out how to center my text in the middle of the rectangle after its created. Here's what I have so far, it works but it waits for me to place it. Also I do a lot of panels that are the same size so I also want the lisp to remember the last input so I can continue to use it until I hit escape or return.
If I could get some help I would appreciate it.
(defun C:CRP7()
 (setq cmdold (getvar "cmdecho"))
 (setvar "cmdecho" 0)
 (setq PL (getstring "Enter a Panel Label :"))
 (setq PA (getpoint "Select Panel Area :"))
 (command "-boundary" "Advanced" "Island" "No" "Nearest" "" pa "")
 (command "_.change" (entlast) "" "_p" "_la" "Router - Green - V groove" "")
 (setq ts(getvar "textsize"))
 (setq tsty(getvar "textstyle"))
 (if(= 0 (cdr(assoc 40(tblsearch "style" tsty))))
 (command "text" "Justify" "Center" pa ts 0 PL)))
 (setvar "cmdecho" cmdold)
Thanks Brian
  • Replies 20
  • hmsilva
    8
  • BrianTFC
    6
  • Tharwat
    3
  • BIGAL
    2
Hi Brian,
if you are not using AutoCAD 2015, try the following program.
The 'bpoly' function, is generating an error in AC2015, (not sure why)...
Change the default prompt "123" to a panel size.
(vl-load-com)
(defun c:demo ( / adoc bp cen lays msp pa pl plo reg sfa txt)
 (setq adoc (vla-get-activedocument (vlax-get-acad-object))
       msp (vla-get-modelspace adoc)
       lays (vla-get-layers adoc)
 (vla-add lays "Router - Green - V groove")
 (while (and (setq pa (getpoint "\n Select Panel Area: "))
             (setq pl (getstring (strcat "\nEnter a Panel Label <" (cond (*pl) ("123")) ">: "))
                   *pl (cond ((/= pl "") (strcase pl)) (*pl) ("123"))
             (setq bp (bpoly pa))
     (setq plo (vlax-ename->vla-object bp)
           sfa (vlax-make-safearray vlax-vbObject '(0 . 0))
     (vla-put-layer plo "Router - Green - V groove")
     (vlax-safearray-put-element sfa 0 plo)
     (setq reg (car (vlax-safearray->list (vlax-variant-value (vla-addregion msp sfa))))
           cen (vlax-get reg 'centroid)
     (vla-delete reg)
     (setq txt (vla-AddText msp *pl (vlax-3D-point (trans cen 1 0)) (getvar 'TEXTSIZE)))
     (vla-put-alignment txt 10)
     (vla-put-textalignmentpoint txt (vlax-3D-point (trans cen 1 0)))
     (vla-put-rotation txt (angle (list 0 0)(getvar 'UCSXDIR)))
Hope that helps
Henrique
Edited by hmsilva
Code revised
Perhaps an alternative method if you entlast the bpoly then get 'coordinates then middle of 1st and 3rd is center point.
(defun getcoords (ent)
   (vlax-variant-value
     (vlax-get-property
   (vlax-ename->vla-object ent)
   "Coordinates"
(defun co-ords2xy ()
; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
(setq numb (/ (length co-ords) 2))
(setq I 0)
(repeat numb
(setq xy (list (nth (+ I 1) co-ords)(nth I co-ords) ))
(setq coordsxy (cons xy coordsxy))
(setq I (+ I 2))
) ; end repeat
(setq co-ords (getcoords (entlast)))
@ Henrique
Don't you think with me that it is better to move the functions to a separate sub-function to get the Activedocument , ModelSpace , Layers collection then Adding a new layer out of the loop of the while function ?
Regards :)
Like Tharwat you will see in my code 2 defuns because I have 1 in my library lisp for std stuff that I use all the time. My post about civ3d lables opens the Aec database only defun in new code. Same Getval nice dcl for input. Its got to the stage where I need to go through all code and standardise.
@ Henrique
Regards :)
Hi Tharwat,
of course you're right! :)
The code at #3 was written with an 'if' function, when posted, I saw that the OP wanted the code in a loop, and I modified it (quick and dirty) to a 'while'...
My primary goal was, trying to demonstrate to OP an alternative method, and above all, trying to pass the idea that we should validate the return data from a function, before submit that data to another function/command.
Code in message #3 revised.
Cheers
Henrique
Undoubtedly it's nice :thumbsup:
I'm using AutoCAD 2015, I just haven't gotten a chance to update my info on here. so how do we fix this?
That's bad news!
Brian, I don't have AC2015 in this ooolllddd laptop, but I remember some threads on a generated error by 'bpoly' function on AC2015, I don't know if it has been corrected in some SP, or not...
The error was an endless loop in 'bpoly', if you have availability to try the code, try the code in a new dwg, and with only one open dwg, in case you have to 'kill the process'.
Tell me if it worked or not.
If not, probably we'll have to change the 'bpoly' to a command, and test a valid new 'entlast'...
It should work as expected, in AC2015 also
(vl-load-com)
(defun c:demo ( / adoc bp cen ent-l lays msp pa pl plo reg sfa txt)
 (setq ent-l (entlast))
             (vl-cmdf "-boundary" "Advanced" "Island" "No" "Nearest" "" pa "")
             (setq bp (entlast))
             (not (eq ent-l bp))
     (vla-delete reg)
     (setq ent-l bp)
Hope that helps
Henrique
Edited by hmsilva
add code
Henrique,
It runs perfect thanks so much. I changed the same line as you did but I couldn't remember the
(vl-cmdf )
I understand why you use the
(setq bp (entlast))
to get (BP) but what does
(not (eq ent -1 bp)
mean?
thanks again to everyone for all your help...:D
Brian
Henrique,
...what does
(not (eq ent -1 bp)
mean?
Brian
You're welcome, Brian!
the
(not (eq ent-l bp))
is for testing a valid new bpoly, just test if not equal to last entity before the 'boundary' command.
You didn't test the 'bpoly' function on AC2015, correct?
Cheers
Henrique
Ok I would like to change the color of the layer when its being created where in this line would I do that?
Brian
I use a simple macro to center text.
^C^C.MTEXT;\J;MC;L;A;1X;
Pick to start and pick the opposite corners of the panel, type in label.
Just another option to consider.
Ok, second attempt....
To change the layer color, try
(setq lay (vla-add lays "Router - Green - V groove")
(vla-put-color lay 3);; for color 3
Henrique
okay had Dumb a** attack I took out
(not (eq ent-l bp))
and it worked great. now I know what you meant by the test line.
thanks
Henrique
