iParts
IronHorse
I created a simple iPart, a box with two different thickness (64mm and 76mm)
I name these #1 and #1D. I open assembly and Place these iParts, with table
I can easily choose wich one I want. But how do I do to easily change all at the same
time? Do I need to use iAssembly in any way?
Standardformat.zip
You can use an iAssembly or you can use an iLogic Rule with the proper names of the Factories to switch out to another Tabled Row.
Also consider your iPart carefully and if an iLogic component maybe a better choice in your modeling. Usually I say it like this... if I have an insurmountable amount of configurations then I use iLogic. If I have a very specific set of values and if it is usually a pretty small chart I will either use Derived Components and / or iParts.
Thanks for your reply, yes ILogic was one of my choises as well. But how do I Control my tables from iAssembly? When I Open my iAssembly I want to get a choise of choosing
either #1 or #1D to get the right set up..
