Visual Styles in drawing
Big Mike
If by different visual styles you mean the options for Shaded, Hidden Line, and Hidden Line removed...then yes. On each view you want to change, Edit the View, then simply uncheck the box called Style from Base or Parent. Its a little check box that will allow you to change that view's style.
