SCORE Posted February 20, 2015 Share Posted February 20, 2015 I usually work in the three viewports left configuration with the left window in top, the right in sw iso and the bottom right in front. is there a way to save this somewhere so when I open a new drawing I can go straight to it? or maybe a lisp routine to set it all up? I already made some lisp routings to get there but it takes about 4 steps. thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 20, 2015 Share Posted February 20, 2015 Model space or paper space viewports? Quote Link to comment Share on other sites More sharing options...
SCORE Posted February 20, 2015 Author Share Posted February 20, 2015 Model space Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 20, 2015 Share Posted February 20, 2015 Why wouldn't you already have this setup in your template file? Quote Link to comment Share on other sites More sharing options...
SCORE Posted February 20, 2015 Author Share Posted February 20, 2015 Most of the drawings I work in are already started by somebody else. but I could do that for when I start new dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 20, 2015 Share Posted February 20, 2015 Most of the drawings I work in are already started by somebody else. but I could do that for when I start new dwg OK, that's what I thought you asked in your first post. Then you went and changed the criteria. Looks like you're still in need of that lisp routine. Quote Link to comment Share on other sites More sharing options...
SCORE Posted February 20, 2015 Author Share Posted February 20, 2015 ive made 1 lisp to get the view port configuration, and 3 other lisp to get to the view I want, I just don't know how to tie them all together and make it on command Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 20, 2015 Share Posted February 20, 2015 Sounds like too much work to me. I would have used the Action Recorder and skipped the whole lisp thing. Record a macro, save it, play it back. Quote Link to comment Share on other sites More sharing options...
SCORE Posted February 20, 2015 Author Share Posted February 20, 2015 ok ive never messed with the action recorder, ill give that a shot Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 20, 2015 Share Posted February 20, 2015 It will give you something to do until one of the lisp gurus show up to assist you with your custom routine. Quote Link to comment Share on other sites More sharing options...
SCORE Posted February 20, 2015 Author Share Posted February 20, 2015 that action recorder is awesome! it worked first try.. is there a way to turn your recording into a command or have a lisp activate it? Quote Link to comment Share on other sites More sharing options...
SCORE Posted February 20, 2015 Author Share Posted February 20, 2015 never mind I figured out how to make a lisp out of it! im going to have lots of fun with this action recorder thing! Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 20, 2015 Share Posted February 20, 2015 I've absolutely no clue. Minor parlor tricks I can handle. For real magic you have to wait for a professional. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 20, 2015 Share Posted February 20, 2015 Score a good idea is to post code it may be useful for some one else and others will other suggestions on how to improve. Quote Link to comment Share on other sites More sharing options...
SCORE Posted February 20, 2015 Author Share Posted February 20, 2015 well here is my lisps I made, there pretty simple (defun C:v3 () (command "-Vports" "3" "l") ) (defun C:1 () (command "-VIEW" "SW") ) (defun C:5 () (command "-VIEW" "TOP") ) (defun C:6 () (command "-VIEW" "FRONT") ) I figured out after you make you action recorder whatever you name it you can type that into the command line and it will play the action. so I named it v12, it works like a charm. im still going to try and figure out how to make a lisp to do everything Quote Link to comment Share on other sites More sharing options...
SCORE Posted February 20, 2015 Author Share Posted February 20, 2015 is there a command to toggle viewports in model space? I think I would need that to make my lisp.. Quote Link to comment Share on other sites More sharing options...
troggarf Posted February 21, 2015 Share Posted February 21, 2015 is there a command to toggle viewports in model space? I think I would need that to make my lisp.. Ctrl + R will cycle through viewports in both model and paper space Quote Link to comment Share on other sites More sharing options...
SCORE Posted February 23, 2015 Author Share Posted February 23, 2015 I wouldn't know how to implement ctrl + R into a lisp. is there a command? my ctrl + R is set up as a hot key for something else Quote Link to comment Share on other sites More sharing options...
