acadesign09 Posted February 22, 2015 Share Posted February 22, 2015 Can anyone has good heart to help and give me solution on my problem. This is the problem, when i draw any object it appears always on the object small rectangular blue in color. The worse on this is, it disturb me always, when im moving it(the object with blue), all object being move too. And then it always hang for a minutes always and always. Plz help Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 22, 2015 Share Posted February 22, 2015 It sounds like you have a feature called CONSTRAINTS enabled. The feature can be disabled and the constraints removed. To turn off constraints set the variable CONSTRAINTINFER to "0". To Delete Geometric Constraints: Enter the command DELCONSTRAINT at the command line, then ENTER. Select the object or objects to delete constraints from, then ENTER. Quote Link to comment Share on other sites More sharing options...
