Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 32
  1. #11
    Senior Member
    Hondatek's Computer Details
    Win7
    dell T5400, dell optiplex 745
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    As you’re connecting the node points, note how the sides of
    each grid square, formed by a spot elevation at each corner,
    will contain two and only two intersections that belong to the
    same contour interval. (This is true in all instances, except
    where a contour intersection happens to be in the same
    location as a spot elevation that serves as one of the grid
    square’s corners.) If you find a square that has only a single
    node for a contour interval, check to make sure you didn’t
    miss marking down another intersection point.
    • Use the PEDIT command to establish the properties of
    each contour line.
    1. Select each polyline, choose the Ltype option, and
    then choose the On option. Doing so makes the
    hidden linetype properties visible even if the line
    segment isn’t very long.
    2. For all contour lines except those marking the
    70-foot, 80-foot, and 90-foot intervals, also choose
    the Fit option for each polyline. Doing so will allow
    the polyline to curve between node points.
    • Once you’ve drawn the existing contour lines, you can
    draw the existing roadways. The main roadway is Cedar
    Park Drive.
  2. #12
    Full Member ConfusedStudent's Avatar
    AutoCAD 2013
    Jan 2015
    Montana
    40
    Look at the thread "need help for penn foster civil drafting project" started by Harpal. it may help you.
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Contour lines generally do not have sharp points.
  4. #14
    AutoCAD 2013
    Jan 2015
    Montana
    40
    Oh good I might have gotten it right this time.
  5. #15
    Senior Member
    Win7
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    Confused what line did you use? I used the polyline just as instructions read.
  6. #16
    Senior Member
    Win7
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    this one Remark. ill do this when i get home. by running the PEDIT command and selecting a polyline then the FIT option the polyline will be fitted with a curve that passes through each point.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    That's the trouble with asking and answering questions that span two threads. A question could be asked in one thread but mistakenly answered in the other. Makes following the course of the conversation problematic.
  8. #18
    Senior Member
    Win7
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    sorry remark. will work on just one thread one question at a time.
  9. #19
    Senior Member
    Win7
    AutoCAD 2013
    Oct 2014
    Houston, Tx
    113
    I got it!!!! Yay! Thank you
  10. #20
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    From what I can tell it looks good.
  1. Penn Foster Civil Project, check
    By Hondatek in forum Student Project Questions
    Last Post: 1st Feb 2015, 10:56 pm
  2. Penn Foster Civil Drafting project plate 3 and 4
    By sorsini in forum Student Project Questions
    Last Post: 5th Sep 2014, 10:44 am
  3. penn foster civil plate 1
    By jcoots17 in forum Student Project Questions
    Last Post: 13th Sep 2012, 11:17 am
  4. Penn Foster-Structural Project, Plate 2
    By Rocktamusprime in forum Student Project Questions
    Last Post: 25th May 2012, 03:32 pm
  5. Structural drafting project Plate 2 (penn foster)
    By ANC2008 in forum Student Project Questions
    Last Post: 13th Jul 2011, 11:47 pm
