beyondforce Posted February 23, 2015 Share Posted February 23, 2015 Hello there, I'm quit new to Inventor and I hope someone could help me with this annoying challenge. I wan to create a Spur Gear based on a Diameter. I was reading a lot about spur gears, but what I can't figure out is, how to create a spur gear with a specific outside diameter in Inventor. The outside diameter should be 600 mm and the number of teeth around 150. I have tried to play with the Spur Gear tool under the Design tab, but with no luck. I would REALLY appreciate it if someone could help me with that! Cheers, Beyondforce. Quote Link to comment Share on other sites More sharing options...
