DECHAL Posted February 23, 2015 Share Posted February 23, 2015 Hi All, I've got a Cabinet Vision DXF export. I now need to send it to my CNC machines. Problem is that all the holes on the part (dxf) are not circles they are a number of small lines that form a circle. My CNC uses the Radius of the circles to select the drill bit so I can't use these Cabinet Vision Files directly. What I need is a way to change all Poly Lines to a Circle. Is there a way to do this? Regards, DECHAL. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 23, 2015 Share Posted February 23, 2015 Post a dwg for any one to do anything need real data. You dont want convert all plines to circle only some. Quote Link to comment Share on other sites More sharing options...
DECHAL Posted February 24, 2015 Author Share Posted February 24, 2015 DXF attached. This is from Cabinet Vision. All Circles are made up from a number of small line. Would like to turn all lines to circles Regards, DECHAL. gab.dxf Quote Link to comment Share on other sites More sharing options...
zaphod Posted February 24, 2015 Share Posted February 24, 2015 I can't open that, others might have the same issue. "Invalid or incomplete DXF input -- drawing discarded." Quote Link to comment Share on other sites More sharing options...
DECHAL Posted February 24, 2015 Author Share Posted February 24, 2015 I had the same problem. It did open in the software that we do your cnc programming form. Also opened it in a package call progeCAD. AutoCAD (autodesk) have a problem opening it, don't know why. I'll see if I can back save it. Regards, DECHAL Quote Link to comment Share on other sites More sharing options...
eldon Posted February 24, 2015 Share Posted February 24, 2015 If you delete the first 60 or so lines of the DXF file down to the start of the ENTITIES section, then it opens up. Quote Link to comment Share on other sites More sharing options...
BKT Posted February 24, 2015 Share Posted February 24, 2015 I opened the dxf in BricsCAD, then ran Lee Mac's LISP on the 61 "circles" and that worked for me. His code is posted here: http://www.cadtutor.net/forum/showthread.php?35409-Polyline-to-circle&highlight=region Quote Link to comment Share on other sites More sharing options...
