AutoCAD comes with several attributed blocks in various shapes, but they are sort of hidden. If you create or edit an MLEADER style, you can see these blocks. Of course if you need blocks like this often, you can add them to your template drawing(s). But what if you are working in a drawing not started from your template? Here is how to add these blocks to any drawing. As you can see here by looking at the INSERT dialog, this drawing contains no blocks. Close the Insert dialog, and open the Multileader Style Manager (MleaderStyle command) Either edit an
More...
