rafaelrafa10 Posted February 24, 2015 Share Posted February 24, 2015 Hey guys. I'm facing this problem: in the .jpeg attachment, I notice that the top bar (the one with the undo button, etc) has some transparency, and therefore, it's hard to read. Can anyone tell me how I can change that? Thanks, Rafael. Quote Link to comment Share on other sites More sharing options...
nestly Posted February 24, 2015 Share Posted February 24, 2015 That might be a product of your Windows color/theme settings. Try changing Windows to a different theme, and or switch to a "Basic" theme instead of Windows Aero. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted February 24, 2015 Share Posted February 24, 2015 Wonder if it could be the result of an inadequate graphics card? *not sure* I say that, only as I use Aero theme and my QAT is _not_ transparent at all (only title bar, etc.) Quote Link to comment Share on other sites More sharing options...
nestly Posted February 24, 2015 Share Posted February 24, 2015 Also might be worth noting which version you're using. Your user profile says AutoCAD Mechanical 2011, but the screenshot is definitely not 2011... probably 2014. Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 24, 2015 Share Posted February 24, 2015 Your Windows Desktop task bar, and the entire AutoCad, and probably any other program window frame is transparent. It is your Windows customization settings, not AutoCad. Quote Link to comment Share on other sites More sharing options...
lrm Posted February 25, 2015 Share Posted February 25, 2015 If you are using Windows 7, click the Start button (lower left of screen) and then go to Control Panel, Personalization, Window Color, and uncheck the box Enable Transparency. I find the transparent background of the Windows frame confusing at times. Quote Link to comment Share on other sites More sharing options...
