Rendering output issue
4RIDERS
Trying using High or Presentation. And as Tannar mentioned, try bumping up the photon count and sampling radius: http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-6CD14B72-C6F6-4CD4-BCD1-47C2D0E1EF39-htm.html
Also, you might want to check out some tutorials: https://www.google.com/?gws_rd=ssl#q=autocad+rendering+tutorial
It's difficult to read the settings on that little screenshot, but here goes:
Your sampling is way out of whack. Change Min Samples to 4 and Max Samples to 16.
Change your Ray Tracing Max depth, relections & refractions to 9.
Change your Photons/Sample to 1000.
Change Final Gather Rays to 1000.
If those settings don't solve the problem, try increasing photons and rays or upload the file here, or put it on Dropbox, and I will take a look at it. Just make sure to use Etransmit to zip up all your files.
