Problem with select
gittie32
Hi! There's a glitch in my program. If I select an object and then try to command like delete or move it tells me to "select object"
also if I select an object to change the layer, it doesn't allow me
Change PICKFIRST to 1, or go to Options >> Selection tab, and select NOUN/VERB Selection. This also set the system variable PICKFIRST to 1.
While you are at it, make sure PICKADD is also set to 1.
