Results 1 to 4 of 4
Thread: Mtext
    Forum Newbie
    AutoCAD 2013
    May 2014
    1
    Default Mtext
    I have a question about MTEXT...
    specifically the tab and indents at the top of the MTEXT input window, how can I set the "tolerance" of the ruler? currently the ruler shows 1/8" increments and will not allow me to set new Tabs between the tick marks. I want to be able to click new tabs at 1/16" increments. Is there a setting for the tolerance or a good way to set tabs with out manually having to type them in the paragraph window?
    Thanks in advance!!
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,720
    Quote Originally Posted by TOBYBEAR View Post
    Thanks in advance!!
    Double click the Tab Scale Bar, or click the Paragraph button (third from left) on the mtext edit box. A dialog box will appear that will allow you to add, modify, or remove increments. Type an increment into the upper box and click add.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    AutoCAD 2013
    Nov 2011
    5,985
    Dana, I was all set to post a similar response, until rereading the OP's post,
    as stated, the OP is aware of this option, and looking for an easier way than entering via the Paragraph dialog.
    But hey, we wanted to help, right?
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,720
    Quote Originally Posted by Dadgad View Post
    Yeah, well. I was sleepy. I guess I went around to the back door in order to not simply say, "No, there isn't."
    I suppose, an option would be to set this up in a template drawing so one only has to do it once.
  1. Sum Numbers in Mtext Fields to Mtext Field
    By muurr in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th May 2017, 05:27 pm
  2. Use often MText?
    By Alex Moiceanu in forum AutoCAD General
    Last Post: 1st Dec 2011, 03:45 pm
  3. Mtext
    By Marc5 in forum AutoCAD General
    Last Post: 4th Jun 2010, 02:16 pm
  4. Can Lisp use mtext to make multi string mtext editor?
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Dec 2006, 03:22 am
  5. MTEXT created in same MTEXT editor on different layers?
    By hyposmurf in forum AutoCAD General
    Last Post: 5th Sep 2003, 12:54 pm
Tags for this Thread
