Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    AutoCAD 2015
    Mar 2015
    4
    Unhappy Inserting a .xls in a autoCAD Electrical 2015
    I have inserted a .xls into a autoCAD drawing. The problem is after I scale up the .xls within the drawing to have the text a good size to read. Part of the .xls is outside the drawing border. Can I break up the .xls and put in two autoCad drawings and still keep in the integrity of the .xls? If not what is the best solution?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    What is the purpose of the spreadsheet?
    Forum Newbie
    AutoCAD 2015
    Mar 2015
    4
    the xls is material reference info.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    No provision for tracking that natively in ACADE?
  5. #5
    Forum Newbie
    AutoCAD 2015
    Mar 2015
    4
    Thanks for your help.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    I was asking a question.
    If there is no provision for tracking materials built into AutoCAD Electrical then you have a couple of options. Insert the spreadsheet as an OLE object or use the TABLE command with the Data Link feature where you can specify a range of cells thereby allowing you to split the spreadsheet up between two drawings.
    Found this reference to "bill of materials" re: ACADE 2015.
    http://www.autodesk.com/products/aut.../all/list-view
  7. #7
    Forum Newbie
    AutoCAD 2015
    Mar 2015
    4
    I'm sorry I didn't understand. Thanks again for your help. I will try that and let you know how it goes.
  8. #8
    Junior Member
    Electrical 2013
    Apr 2014
    20
    You don't have to insert as an OLE you can just copy and paste it, then use OLE to edit it. Try to stay away from data links, the excel sheet linked has to be stored with the drawing forever, it's a pain when the link is broken. I use ACADE as intended and generate many reports for my drawing sets, I never insert/paste Excel spread sheets.
  9. #9
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,511
    We print the XLS to PDF, then insert the PDF.
    Guaranteed WYSIWYG results.
    It also works going XLS->DWF->DWG
    R.K. McSwain
    CAD Panacea | twitter
  10. #10
    Junior Member
    Electrical 2013
    Apr 2014
    20
    Again use the default_cat.mdb data base to insert part numbers into the schematic devices so you can run a BOM report. Some one told me once, they don't use the mdb data base because they have a parts data base and don't want to up keep two parts data bases. So they developed an automated spread sheet to create their BOM, then inserted into the drawing. What they didn't realize is that automated spread sheet is another data base of sorts and the effort into creating and implementing that spread sheet could have been used to populate the default_cat.mdb with the parts, if they weren't already there, and used to run BOM reports as intended by Autodesk.
    Bottom line utilize the tools in ACADE for smart clean drawing sets. I run; Fuse chart, motor chart, component chart, 2 BOM's, terminal jumper chart, WPS and CPS reports in my drawing sets.
  1. Can AutoCAD 2015 be used with Visual Studio 2015?
    By muck in forum .NET, ObjectARX & VBA
    Last Post: 22nd Feb 2015, 07:56 pm
  2. Importing an Autocad 2015 3D dwg file into Inventor 2015
    By dalzielcad in forum Autodesk Inventor
    Last Post: 30th Jan 2015, 07:42 pm
  3. AutoCAD for Mac 2015 and AutoCAD LT for Mac 2015 Now Available
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 14th Oct 2014, 08:10 pm
  4. AutoCAD 2015 SP2 is now available
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 18th Sep 2014, 04:00 pm
  5. Replies: 3
    Last Post: 20th May 2014, 05:54 pm
