Results 1 to 3 of 3
    Forum Newbie the_arkitek's Avatar
    AutoCAD 2015
    Mar 2015
    4
    Default Losing the Linetype from XREFS
    Hello,
    We xref and draw in Model Space then use viewports with title blocks scaled accordingly to the LTSCALE in Paper Space (i.e. 1"=50'-0" would have a setting of LTSCALE: 600).
    So this happens frequently....We receive a background from architect, civil engineer, etc.. and after cleaning up the background and then setting up our drawings, thus xref in the background; the linetypes from the xref get lost (i.e. say a dashed line will show continuous).
    Any help would be greatly appreciated!!
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    What happens when you set the LTScale to 1?
    Drafting is a breeze.
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    AFAIK, LTSCALE is drawing specific, so the host drawing sets the linetype scaling. The exception is if the objects have object level property overrides applied. IMO, it would be better if you changed your technique to use a "normal" LTSCALE (0.5 or 1) and then take advantage of AutoCAD's automatic linetype scaling (MSLTSCALE=1 PSLTSCALE=1) but the other option is to use the Properties Palette to change the XREF object's LTSCALE to 1/600 to counteract your host drawing 600/1 LTSCALE.
  1. Linetype scale and XREFs
    By redbeardcad in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Aug 2013, 02:05 pm
  2. Xrefs keep losing their paths!!!
    By Folio in forum AutoCAD Drawing Management & Output
    Last Post: 27th Mar 2012, 06:42 pm
  3. gray scale xrefs vs. xrefs with full range of pen colours
    By corinne in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2008, 09:56 am
  4. Linetype scales - how to do it properly. Inc XREFS
    By spittle in forum AutoCAD Drawing Management & Output
    Last Post: 6th May 2008, 03:33 pm
  5. Losing my xrefs!
    By nscherneck in forum AutoCAD Beginners' Area
    Last Post: 11th Oct 2006, 11:23 pm
Tags for this Thread
