Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Forum Newbie
    not specified
    Jun 2006
    7
    Unhappy AutoCAD to SketchUp
    I really need help to transfer my home plans from Autocad 2006 to SketchUp (free version). I plan to build the house and I need some interior ideas (materials........). I don't have time to learn more about SketchUp, I'm really in rush. If somebody have time to do that for me I'll be grateful. I can send attach dwg.
    Last edited by CADTutor; 14th Sep 2006 at 05:28 pm. Reason: Added more descriptive title
    Super Member JBullseye74's Avatar
    Construction
    JBullseye74's Discipline Details
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    768
    Send it to me if you like.... i'll pm you my address.
    AutoCAD 2010
    '"Accept that some days you're the pigeon, and some days you're the statue."
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    how can you not learn SketchUp while knowing AutoCAD? lol it's about the easiest program i've probably ever used, next to Word or Email....
    just import your dwg's into SketchUp, and voila.... :-)
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Forum Newbie
    not specified
    Jun 2006
    7
    I know it's the easiest program on the world but I imported my plans into SkectUp but probably I missed some steps because I can't use push/pull command................Probably I'm to occupied with all staff about building home so I'm getting dumb.
    Thanx Jimmy
  5. #5
    Construction
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    768
    ok no problem but you wont be able to push pull straight away. The best way apart from using a ruby is to delete one of the lines and re draw it. That will make the part of the wall a solid and you will be able to push/pull it.
    hope that helps.
    AutoCAD 2010
  6. #6
    Forum Newbie
    not specified
    Jun 2006
    7
    Thank you Jimmi. I just open the file and try to push wall up. And I open forum and found your answer. You knew I'll ask it, right?!
  7. #7
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 7 Home Premium (H)
    Lenovo ThinkStation D20 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Xeon E5503 (W)/AMD Athlon 2 X4 (H)
    4 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Quadro FX 580 (W)/nVidia GF GT430 (H)
    500 GB HDD (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Dell 22" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management
    AutoCAD 2012
    Sep 2002
    Winston-Salem, NC - USA
    4,455
    Jimmy's advise is sound but one way I do it is to use the ACAD lines as a "reference" and just draw on top of these with clean, SU lines. There is even a ruby script to help with the "joining" of ACAD lines in SU but there will still be some clean-up to do. Best of luck
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ - - http://cad-guy.tumblr.com/ -
  8. #8
    Super Member CADken's Avatar
    CADken's Computer Details
    Microsoft Windows 7 Ultimate
    Toshiba Satellite A135
    Intel Pentium T2080 @ 1.73GHz, 1733 Mhz, 2 Core(s), 2 Logical Processor(s)
    Slot 1: 1GB DDR Slot 2: 1GB DDR
    Toshiba 110GB, Maxtor External HD 120GB
    Notebook Monitor + 22" NEC AccuSync LCD223wxm
    AutoCAD 2010
    Jun 2006
    East Coast - Pennsylvania
    828
    i re-draw almost every line.. it's tedious, but for a freebie program, it does wonders
    Fireman | Draftsman | Fabricator
    Running Windows 7 with AutoCAD 2010
    the Battalion East Side Pride
  9. #9
    Senior Member boofredlay's Avatar
    AutoCAD 2007
    Apr 2005
    Huntsville, Alabama
    274
    Maybe a little late for this but if you have good cad technique, there should be no need for redrawing every line.
    I usually take a cad drawing, save as... clean it up (just walls etc...) then bring it into SU. Then use the "make faces" ruby and all your cad lines will close in. Then start pushin' & pullin'.
    Hope that helps.
    Eric Lay
    Visit my Blog - View my Portfolio - Revit - SketchUp - Autocad - Photoshop - Twilight Render - Thea Render
  10. #10
    AutoCAD 2010
    Jun 2006
    828
    Quote Originally Posted by boofredlay View Post
    Hope that helps.
    **slaps self on forehead** i knew there was an easier way
    BTW:
    http://cadtutor.net/forum/showthread.php?t=8392
    in this thread there is a few links to add on to your "Materials" very good
  1. SketchUp Information
    By CADTutor in forum SketchUp
    Last Post: 7th Mar 2012, 09:02 am
  2. SketchUp to AutoCAD 2006
    By Ters in forum SketchUp
    Last Post: 13th Mar 2008, 09:09 pm
  3. sketchup 3D problems
    By danj0nes in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Mar 2004, 03:34 pm
