The AutoCAD Hardware Certification Database file contains the latest data that AutoCAD uses for optimizing the performance of graphics hardware.
http://www.autodesk.com/autocad-graphicscard
http://usa.autodesk.com/getdoc/id=DL7440746
The current version of the Hardware Certification Database is: 1.1.1.4. If the version of the local copy of your database is older than the current version then your database needs to be updated.
Affected Products
AutoCAD® 2007
AutoCAD® Electrical 2007
AutoCAD® Mechanical 2007
Autodesk® Architectural Desktop 2007
Autodesk® Building Systems 2007
Autodesk® Civil 3D® 2007
Autodesk Inventor® Professional 11 (1)
Autodesk Inventor® Series 11 (1)
Autodesk® Land Desktop 2007
Autodesk Map® 3D 2007
Autodesk® AutoCAD® Revit® Series Building 9.x (2)
Autodesk® AutoCAD® Revit® Series Structure 3.x (2)
(1) Apply this patch only if the installation includes AutoCAD Mechanical 2007 or Autodesk Mechanical Desktop 2007.
(2) Apply this patch only if the installation includes AutoCAD 2007.
Changes from the previous database
Changes to version 1.1.1.4
- Smooth Line display is disabled for ATI cards using driver 6618.
Note: It is recommended that you disable the Smooth Line display feature when OpenGL is configured for a non-certified ATI card that uses a driver different than 6613.- ATI Radeon cards are now Supported for AutoCAD when using drivers 6606 and 6618 (Catalyst 6.4 and 6.6). These cards do not support the Selection Area display fill area. If you see artifacts when using the Selection Area, you can turn it off setting SELECTIONAREA to 0.
- The following tables display new graphic cards and drivers that have been added to version 1.1.1.4. The tables also show existing graphics cards whose drivers have been updated since version 1.1.1.3.
Click here to view the complete list of certified graphic cards and drivers.
More...
Between the Lines - Autodesk blog by Shaan Hurley
