Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 53
    Junior Member
    AutoCAD 2014
    Mar 2015
    16
    Default 2014 paper space /viewports in metric cant scale correctly !
    Hello
    Having some issue with AutoCAD 20014 scaling my view ports correctly my first metric drawing (drawn 1:1) Im try to create 1:100 scale viewport on 8"x10" paper ....
    when I plot my paper space 1:1 I cant get the correct scale in the view port for 1:100 ??? what im I missing, ie... what should be my scale properties to achieve 1:100 scale in edit drawing scale menu
    Ty
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,728
    Are you selecting the viewport and picking the scale to apply to the viewport? Exactly how are you applying the scale to the viewport? Can you attach the drawing to your next post here?
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,583
    You shouldn't try to do metric on 8"x10" paper, it should be the appropriate size for metric which would be ~200x254. The relationship between MS and PS will never work out unless you are matching systems in both, either both imperial, or both metric (SI).
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Junior Member
    AutoCAD 2014
    Mar 2015
    16
    Default attached drawing
    Quote Originally Posted by Dana W View Post
    attach file, I have tried selecting the viewport frame only ....also ....just clicking within model with out panning after changing the scale
    im printing my paper space 1:1
  5. #5
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,728
    Quote Originally Posted by rkent View Post
    Wait. I should have asked about the units. What units are you drawing in?
    It will only work if your dwg units are metric
  6. #6
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,728
    I changed my prior post.
  7. #7
    Junior Member
    AutoCAD 2014
    Mar 2015
    16
    new to 2014 not 100% about the units?
  8. #8
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,728
    I just looked at the drawing. Your dwgunits are inches and so are your paperspace units. The viewport scales are a ratio of ONE paperspace unit = NNN modelspace units. Since the drawing is only about 8" wide, why plot at 1" = 100"? 1:3 works fine One paperspace inch = 3 modelspace inches.
  9. #9
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,728
    Quote Originally Posted by eloid View Post
    Then that begs the question, are you in a metric or imperial country? If you are imperial (feet & inches) then see my prior post.
  10. #10
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,728
    Now my post #5 makes no sense at all. I should have looked at the drawing first.
  1. Cylinder not printing correctly from paper space
    By dct73 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Oct 2011, 04:36 pm
  2. two viewports onto one paper space?
    By vanglak in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Feb 2011, 01:29 pm
  3. viewports in paper space.
    By starman in forum AutoCAD Beginners' Area
    Last Post: 28th Jun 2010, 09:24 pm
  4. why my line type does not show on paper space correctly!!!
    By alessandro754 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd May 2007, 04:46 pm
  5. Setting Paper Space to Metric Scale
    By DRD in forum AutoCAD Beginners' Area
    Last Post: 16th Jun 2006, 07:25 pm
