Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 53 of 53
  1. #51
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Quote Originally Posted by eloid View Post
    I had to scale it my self, after following your step ... step by step..... I believe its correct now for scaling.
    Problem 2.... In model space my dashed lines set bylayer look ok.... in model space but in paper space there solid. In paper space tried changing the properties under bylayer / other/ hide details.
    I set (use paper space units for scaling off) (blank) try regen my paper space viewport... no luck.
    then i tried changing my global setting of (1 default to 25.4 -30) then doing a regen command in paper space again and the lines are still solid vs model why?
    I figured out What I told you incorrectly to do when running -DWGUNITS. I forgot to change the default <YES> to <NO> in answer to the prompt below
    ** WARNING: you have changed the unit for this drawing database. **
    ** All new objects will be drawn according to the new unit, but **
    ** existing objects will not change size unless you specifically **
    ** ask to have automatic scaling occur. **
    Scale objects in current drawing to reflect change in units? [Yes/No] <Yes>: y I should have indicated that the correct answer here is NO. We do not want the existing objects scaled. That is why they came out Way Too Small when you did it. My bad. I was thinking backwards for some reason right then. This line >> ** existing objects will not change size unless you specifically ** is counter-intuitive and made me second guess myself.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  2. #52
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Maybe AutoDesk should consider making acadiso.dwt the default template file for any copy of AutoCAD sold outside of the United States. Then we can stop having this conversation ad infinitum.
  3. #53
    Senior Member sparkyuk's Avatar
    sparkyuk's Computer Details
    Windows 7
    AutoCAD 2010
    Jan 2007
    UK
    365
    And also give the ability to select English as default instead of having only having "American English" to select what ever that is lol
  1. Cylinder not printing correctly from paper space
    By dct73 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Oct 2011, 04:36 pm
  2. two viewports onto one paper space?
    By vanglak in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Feb 2011, 01:29 pm
  3. viewports in paper space.
    By starman in forum AutoCAD Beginners' Area
    Last Post: 28th Jun 2010, 09:24 pm
  4. why my line type does not show on paper space correctly!!!
    By alessandro754 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd May 2007, 04:46 pm
  5. Setting Paper Space to Metric Scale
    By DRD in forum AutoCAD Beginners' Area
    Last Post: 16th Jun 2006, 07:25 pm
