kunekainen Posted March 14, 2015 Share Posted March 14, 2015 Hi everyone; I am trying to write a plugin which asks me to select some lines and while doing it asks for a keyword to show some application forms. Here is the code I have written so far: Public Class Test Dim keyword as string = nothing Public Sub VOLengthtoBlock() Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor tlinelen = 0 lenmultiplier = frmTools.TextBox1.Text Try Dim tr As Transaction = db.TransactionManager.StartTransaction() Using tr 'Select Objects Dim opt As New PromptSelectionOptions() opt.SetKeywords("[Options/Scale]", "Options Scale") opt.MessageForAdding = vbLf & "Select objects or " & opt.Keywords.GetDisplayString(True) AddHandler opt.KeywordInput, AddressOf onKeywordInput Select Case keyword Case "Options" frmTools.ShowDialog() Case "Scale" frmScale.ShowDialog() End Select Dim selres As PromptSelectionResult = Nothing selres = ed.GetSelection(opt) If selres.Status <> PromptStatus.OK Then Return End If Dim selset As SelectionSet = selres.Value 'Get Line Lengths If selres.Status = PromptStatus.OK Then For Each selobj As SelectedObject In selset Dim sent As Entity = DirectCast(tr.GetObject(selobj.ObjectId, OpenMode.ForWrite), Entity) If TypeOf sent Is Line Then Dim curline As Line = TryCast(sent, Line) tlinelen = tlinelen + curline.Length ElseIf TypeOf sent Is Polyline Then Dim curline As Polyline = TryCast(sent, Polyline) tlinelen = tlinelen + curline.Length End If Next tlinelen = CInt(tlinelen * lenmultiplier) bBlockLength = True VOMEditBlock() bBlockLength = False End If tr.Commit() End Using Catch ex As Autodesk.AutoCAD.Runtime.Exception MsgBox(ex.ToString) End Try End Sub Private Sub onKeywordInput(sender As Object, e As SelectionTextInputEventArgs) Me.keyword = e.Input End Sub End class It does not show my form until I exit from the sub and call it again. When i call it again, it just shows the form. I couldn't find the error. Please help. Quote Link to comment Share on other sites More sharing options...
