2005LT grip info
ikqdrum
cannot get grips to show object info... hover over grip at end of line and nothing appears....i.e. stretch/lengthen option, or more important length of line!!!
would also like command line to go away, would also like input to be at cursor tip
THERE IS NO ON DRAWING INFO !!!! I would like to see something!!
  • Replies 25
  • ikqdrum
    13
  • ReMark
    12
  • rkent
    1
Popular Days
yes tip are enabled. not quick properties.... usually there is info that follows cursor ie when you want to draw a line from the center of another, the word "center" would appear at that point, as well as the center symbol....
You must be thinking of OSnaps.
Re: input at cursor. That's controlled by the Dynamic Input setting.
Re: make command line go away. Ctrl+9 is what you are looking for.
What do you mean "how do you check it?" It's either Enabled or Disabled. Status Bar > Customization icon (far right hand corner of your screen) > Dynamic Input.
You might benefit from taking a basic AutoCAD introductory course. These can be one or two day sessions held at your local authorized AutoDesk reseller. If that isn't an option use your Help file and/or buy a good after-market AutoCAD 2015 book. There are many available.
Edited by ReMark
Changed Task to Status
Please include the letters "LT" in your Profile description.
Edited by ReMark
OP is using 2005 not 2015. My bad.
I put LT right in the header!
Yea, I don't have any of that other stuff....
First day here and the previous guy left this program a WRECK....
Try to remain calm and in your seat please. I was suggesting you also add it to your profile.
What "other stuff" don't you have?
yea, im calm. haha forgot to update profile with job change...my bad
so you don't think theres a way to get that on this version?
Ive used 2002LT and it had that input...
like I said, first day here and no other drafters...
will def get a book, cause this little stuff drags the process down
ok, another thing
can only click ON object that needs trimmed or extended, cannot "window" the object
What exactly IS showing in the general area (Status Bar) displayed in my previous image?
Edited by ReMark
im calm,
sorry, forgot to adjust profile with job change
so you think theres no way to get a "version" of dynamic input?
ive used 2002LT, and it had it...
also when I trim or extend a line, I need to hit the line exactly, no way to "window" it?
thanx for help....
im gonna be on here a lot!
Try this re: Dynamic Input. Press the F1 key for AutoCAD Help and type in the words Dynamic Input. Is there a topic on how to enable/disable dynamic input? Yes or no?
And...is the system variable PICKFIRST set to a value of 1?
Edited by ReMark
Do the letters DYN show up in the Status Bar by any chance? What happens if your press the F12 key?
Type DYNMODE at the command line and press Enter. What do you see?
