joao56777 Posted March 17, 2015 Share Posted March 17, 2015 Hi, Please look the drawing attached. I canot do the weld in the union of the two sheet metal. Is it because the intersection is a curve? Thanks. Best regards Soldadura.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 17, 2015 Share Posted March 17, 2015 A weldment is done in an assembly - you have a part. You have two parts in one part file - in the real world this is an assembly of two parts. Your holes are the wrong size - there is no material for the thread. The fasteners will not engage any threads. Use Tapped Hole features to create threaded holes. The Thread feature is for external cylinders. What happened to the dimensions on Sketch1? Have you installed all Service Packs and Updates for your version of Inventor? Quote Link to comment Share on other sites More sharing options...
joao56777 Posted March 18, 2015 Author Share Posted March 18, 2015 A weldment is done in an assembly - you have a part.You have two parts in one part file - in the real world this is an assembly of two parts. Your holes are the wrong size - there is no material for the thread. The fasteners will not engage any threads. Use Tapped Hole features to create threaded holes. The Thread feature is for external cylinders. What happened to the dimensions on Sketch1? Have you installed all Service Packs and Updates for your version of Inventor? [ATTACH=CONFIG]53321[/ATTACH] Hi, No, i have not instaled any patch. Thanks for the thread advice. But, in the back of the drawning that you attached, have too, 2 sides that need to be weld. And inventor gave me an error... Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 18, 2015 Share Posted March 18, 2015 Hi, .... And inventor gave me an error... I don't see new attachment here? Quote Link to comment Share on other sites More sharing options...
joao56777 Posted March 18, 2015 Author Share Posted March 18, 2015 I don't see new attachment here? In the same drawning, please orbit the object and you'll see that miss wel in the edges. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 18, 2015 Share Posted March 18, 2015 Service Packs, Updates and Hotfixes for Inventor 2013-2015 can be found here. http://knowledge.autodesk.com/support/inventor-products/downloads#?sort=score Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 23, 2015 Share Posted March 23, 2015 In the same drawning, please orbit the object and you'll see that miss wel in the edges. I don't see new attachment here. Why would I look at the same "drawing" (actually a drawing is 2D) - model, or in this case, assembly is more proper term. You did not attach your assembly here. As far as I know - you didn't understand anything I wrote in my first response. If you don't understand my instructions - you will need to state specifically what you don't understand. Quote Link to comment Share on other sites More sharing options...
